TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Jan 14, 2016 at 8:41 AM
    #1121
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Run the DTLT headers (no cats) and the URD spec U exhaust (that include a rerouted Y pipe with no cats) and realy like the sounds. The sounds is not annoying. For me the routing of the Y pipe on the spec U exhaust is better than the URD Y pipe and the spec U exhaust is a dual set up with a quiet resonator.
  2. Jan 14, 2016 at 12:22 PM
    #1122
    ThomasMore66
    Dallas/Fort Worth & Durango
    Jealous of the no cat thing. Got my truck inspected this am and the tech didn't look under the truck - just plugged into the obd2 port.
  3. Jan 14, 2016 at 12:45 PM
    #1123
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    You can add the URD Y-pipe and get rid of the 2 rear cats.
  4. Jan 20, 2016 at 8:20 PM
    #1124
    ThomasMore66
    And the bypass electronic hookup I've seen on URD, I'm guessing.
  5. Jan 20, 2016 at 8:27 PM
    #1125
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    No bypass at all....
    It goes 2 oxygen sensors....2 cats (front)
    2 flow sensors. .......2 cats (rear)
    The computer doesn't recognize if you remove the 2 rear cats and the 2 flow sensors. So no check engine light comes on by removing them. Just simply replace the URD Y-Pipe in place of the stock y-pipe assembly consisting of 2 rear cats and sensors.
    Biscuits likes this.
  6. Jan 20, 2016 at 8:32 PM
    #1126
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    The bypass your probably thinking of is when you add headers and in the process remove the 2 front cats and 2 front o2 sensors.......you replace those with o2 simulators to trick the computer thinking the o2 sensors are still installed .....to not throw a code and CEL.
  7. Jan 20, 2016 at 8:45 PM
    #1127
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    @Justus & @STiLL WILL
    I've been eyeballing your exhausts as an alternative to the URD Spec U system. I'm having trouble reconciling spending $1k on am exhaust system that will be beaten on off-road excursions.
    @ThomasMore66
    That's all I've ever seen inspectors do in my area. Then again, the gal who inspected my truck spent more time talking about my truck with me than actually inspecting it.
  8. Jan 20, 2016 at 8:45 PM
    #1128
    Biscuits
    @VolcomTacoma
    What mods have you installed? I know you've been busy...
  9. Jan 20, 2016 at 8:53 PM
    #1129
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
  10. Jan 20, 2016 at 8:55 PM
    #1130
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    @Biscuits .....I commented on your post.....but it came up under your post to still will and Justus.
  11. Jan 20, 2016 at 9:03 PM
    #1131
    Biscuits
    Thanks dude, I appreciate your insight. I'll spend the money and time on quality to get what I want, but at the same time I don't want to needlessly waste it.
    On a related goal, I totaled the cost of all the URD goodies I wanted and immediately knew that it wouldn't pass the Wife Test.
  12. Jan 20, 2016 at 9:04 PM
    #1132
    ThomasMore66
    Don't ask, don't tell.
    Torspd likes this.
  13. Jan 20, 2016 at 9:08 PM
    #1133
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    TRD Supercharger
    URD stealth 2.8 Pulley
    URD Y pipe
    URD Mach III 3" Exhaust
    AFE Stage II SI ProDry CAI
    URD Stage 3 clutch +lightweight flywheel +URD T/O Bearing
    Hurst Core shifter
    When I get time Ill install the DT Short headers and I'm twiddling thumbs for UCON
  14. Jan 20, 2016 at 9:09 PM
    #1134
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Lol....oh I get it.
    Biscuits[QUOTED] likes this.
  15. Jan 20, 2016 at 9:27 PM
    #1135
    Biscuits
    That doesn't work for me lol.
    1.) We're on equal footing when it comes to finances: I buy her boobs v2.0 and I get a new Tacoma. See? Equal.
    2.) She's a gear head (her old RSX Type-S is sitting in the garage) so she'd definitely notice via "seat of the pants" dyno even if I managed (or had a desire) to hide everything else. :spy:
    Nice list there. Dyno #'s yet?
    And you're not the only one waiting for this unicorn UCON...
    SUMOTNK and Torspd like this.
  16. Jan 20, 2016 at 9:37 PM
    #1136
    ThomasMore66
    My wife doesn't ask, I don't tell.
  17. Jan 20, 2016 at 11:38 PM
    #1137
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    My paycheck..... my account.... as long as I pay my bills I have no one to answer to.
    Rock Lobster likes this.
  18. Jan 21, 2016 at 12:43 AM
    #1138
    VolcomTacoma
    Jeff
    NorCal
    No dyno #'s yet. Pretty much waiting to get headers on and tune. Will be getting UCON, 7th injector and water/meth injection at the same time, so I'm hoping for AT LEAST 350 to the wheels.
  19. Jan 21, 2016 at 12:45 AM
    #1139
    VolcomTacoma
    Jeff
    NorCal
    And yea, @Justus, paying all the house bills and mortgage and all the baby stuff means when I buy truck stuff, she has no leg to stand on so I hear pretty much no complaints, just heavy eye rolling.
    Torspd and Justus like this.
  20. Jan 21, 2016 at 3:16 AM
    #1140
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    No big deal till she hits you up for child support etc. How's your savings account and the 401k and college fund for the kid coming along?
