TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Dec 12, 2012 at 9:52 PM
    #101
    Corndawg
    Corndawg Well-Known Member
    Corey
    Utah
    2007 double cab TRD off road Radiant Red
    2.5 inch pro comp lift Cobra XRS 9745 Detector 15 band scanner Pioneer DEH-P6900UB Python 991 remote start/ security. Tinted license plate covers Fog Light Mod PIAA Extreme White 4000K Replacement bulbs Red LED Dome and Map lights LED replacement tail light bulbs Black Weather Tech Floor Liners front and rear
    so spend money on lift and tires tint
  2. Dec 13, 2012 at 2:08 PM
    #102
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Can't, already spent the money on the supercharger.
  3. Dec 13, 2012 at 2:15 PM
    #103
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    They probably said that because they don't know. '05-'11 have the same engine bay setup. S/C fits all of those the same.
    '12, they changed the engine bay and added a new feature from the previous models. And now they have the fit kit for it. Based off of that, I seriously doubt that Toyota changed the engine bay setup again 1 year later for the '13. I would bet that the '12 s/c fits the '13.
  4. Feb 23, 2013 at 11:06 PM
    #104
    Nicky Lam
    Nicky Lam Dog Face Soldier
    Nick
    Somers Point/Mount Laurel, NJ
    2013 Blk DC Off Road
    NOV12: Front windows tinted to matched to rear windows 12NOV12: Fog light anytime mod DEC12: OME 885 w/ 25912 top plate spacers for full 3" lift OME Trim packer Dakar Rear 5 Leaf Packs Total Chaos Uniball Upper Control Arms 2.5° Degree Rear Axle Shims 18JAN13: 17x9 Fuel Kranks 17x9 4.5 BS -12mm Offset 285-70-17 Goodyear Duratracs 23JAN13: OME Carrier Bearing Drop Kit 05FEB13 TRD Aluminum Skid Plate 05FEB13 TRD Stainless Steel Cat Back Exhaust (2012 modified to fit 2013) Auto Mate 5304A (Viper 5704 Equivalent) 2-Way Alarm/Remote Start with Smart Start for iPhone De-Badged All Emblems 30JUL13 Go Rhino Stainless Steel Dominator II Side Steps *not yet installed: Stainless Steel Extended Rear Brake Lines
    2013 super charger kit is avail now on trdparts4u!!!!!!!
  5. Mar 7, 2013 at 5:33 PM
    #105
    BeEatNU
    BeEatNU Well-Known Member
    Nick
    Gardena, CA
    2013 Tacoma Double Cab Limited
    YES YES YES!
    thanks for this.
  6. Jul 9, 2013 at 10:53 PM
    #106
    SABAJA
    SABAJA Well-Known Member
    San Antonio
    13 Baja TX edition
    I'm mulling over whether to get it myself. My dealer said that they couldn't add in the SC on the deal because Toyota specifically says they're not supposed to add it into the deal at the time of purchase. So it HAD to be after the sale.
    Got pricing, they weren't able to beat the kit price from TRDparts4U...but when I showed them the numbers for the whole kit, they said they'd take the $250 difference from the labor charge to install. They said they wouldn't honor the warranty unless it was PURCHASED AND INSTALLED by them. I argued that point saying it should only be the installation--but since they were making an attempt to accommodate me price-wise I told them to give it to me in writing and that I needed some time to come up with the money.
    Personally, the truck to ME, doesn't NEED the SC. But I'm sure it's a beast with it on there. Heard the truck can run 12 flat in the QM with one on there.
  7. Jul 10, 2013 at 1:30 AM
    #107
    S1000RR
    S1000RR Well-Known Member
    2013 TRD Supercharged Sport
    No way it's running 12 flat without extensive mods. You are looking closer to high 13s with just the supercharger.
    Your dealer is screwing with you. I got my 2013 TRD SC online and my dealer installed it and said I had the full warranty since I got it installed by an authorized dealer.
  8. Jul 10, 2013 at 2:10 AM
    #108
    neegdogdig
    neegdogdig Untrained with bad experiences go go go!
    3rd Gen DC V6
    i don't know if it's worth the $ but as a driver i like it, too bad mine trd s/c was leak at the nose drive and need to be rebuilt. now temperature is above 100 and have to wait till it drop to work on the s/c. already got the rebuild kits just waiting for it to cool down. o1 taco limited editions.
    for the trd s/c in every 30k miles you must replace the fluid/oil to prolong the life of the s/c. and when it reach 80-150k miles you might consider replacing the coupler, bearings and nose seal to keep this baby to sing the sound you like to hear when you push the gas paddle.
    to have it and not to have it it's only an option:D.
  9. Jul 10, 2013 at 4:28 AM
    #109
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I like your mods list. Especially considering you have a '13. :thumbsup:
  10. Jul 10, 2013 at 11:37 PM
    #110
    S1000RR
    Appreciate it, especially coming from you. I'm a fan. :D
    Read a lot of your posts from here and xr-underground.
  11. Jul 11, 2013 at 12:45 AM
    #111
    SABAJA
    San Antonio
    13 Baja TX edition
    I know the dealer is screwing with me. I even told them that they were wrong. I straight told the service manager that I didn't have to buy anything directly from them, and that it was the install by the dealer to assure warranty was retained.
    He spouted some other b.s. about a paper trail and then finally gave a quote of $1560 or something for labor. I was said thanks and just walked out. Even at $100 dollars an hour, it doesn't take them 15 hours to put that S/C in. It's scheduled at 6 hrs, but more than likely takes more a long the line of 8 hours taking your time.
    So high 13's huh? Shit. That might make it not worth it for me, not for the 5k total investment. I think I'll focus on the other stuff first and paying down the remainder of the loan. Truck seems to do fine getting me around town and it's not a sports car so as long as I'm able to pass the slow assess on the highway I'm fine.
    I'll probably get it online after talking to other local dealers first to see what sort of labor rate they'll charge for the install.
  12. Jul 11, 2013 at 7:00 AM
    #112
    ATHiker
    ATHiker Well-Known Member
    Tom
    Tennessee
    15 Tundra DC 4X4 SR5 OR 5.7L
    My local dealer quoted my a price of $5600 ($4500 parts / $1100 labor). Even if I can negotiate the price to $5000, not sure I can pull the trigger.
  13. Jul 11, 2013 at 7:04 AM
    #113
    Large
    Large Red
    Save your money, get a garret turbo setup.
  14. Jul 11, 2013 at 7:18 AM
    #114
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
  15. Jul 11, 2013 at 7:45 AM
    #115
    B11
    B11 Well-Known Member
    N.E. Wa.
    2013 TRD Off Road
    Is now SuperCharged
    trdparts4u is where I bought mine a couple months ago. My local dealer where I purchased my Taco couldn't even come close to their price and there was no sales tax and had free shipping. Was a win, win!
  16. Jul 11, 2013 at 9:44 AM
    #116
    SABAJA
    San Antonio
    13 Baja TX edition
    That's what I was pricing it off of, that site. But dealer was saying they wouldn't provide a warranty. Now that I think about it, that have no grounds to do so since TRD says otherwise. They HAVE to provide warranty coverage if its installed by another dealer.
    But regardless, I'm going to keep her NA for now.
  17. Jul 11, 2013 at 9:46 AM
    #117
    Large
    Large Red
    If it's dealer installed your powertrain stays intact, even if it's not dealer installed your powertrain isn't affected so the rep who told you that is an idiot.
  18. Jul 11, 2013 at 11:04 AM
    #118
    SABAJA
    San Antonio
    13 Baja TX edition
    If it's not dealer installed, we get 12 mts or 1 yr on those parts I believe, right? But if it's dealer installed the TRD SC gets the remainder of the 5yr 60k---right?
  19. Jul 11, 2013 at 3:23 PM
    #119
    B11
    N.E. Wa.
    2013 TRD Off Road
    Is now SuperCharged
    If it's installed by a certified Toyota dealer you get whatever factory warranty you have remaining as if it came from the factory with the TRD SC installed.
    I say remaining only because most of these TRD SC kits are installed a few thousand miles after they are purchased new. Mine had around 4,000 miles when I had them install it.
  20. Jul 11, 2013 at 3:25 PM
    #120
    Large
    Large Red
    I'm just clarifying, installing a S/C won't void any warranty. DIY or dealer installed. Yes there is a parts only warranty with TRD however.
