TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Jan 28, 2016 at 4:13 PM
    #1321
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Sorry thats all i have for pics on them.
  2. Jan 28, 2016 at 4:19 PM
    #1322
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    u wont..... ur too fat to flip
  3. Jan 28, 2016 at 4:24 PM
    #1323
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    so thats the key to the backdoor.
    Torspd likes this.
  4. Jan 28, 2016 at 4:28 PM
    #1324
    WOODEX M.E.
    Corey
    Maine
    I think some others have done them with some sort of flip kit.
  5. Jan 28, 2016 at 5:10 PM
    #1325
    ThomasMore66
    Dallas/Fort Worth & Durango
    Dude! They have wheelie bars! Lobster, that's what you need.
    WOODEX M.E.[QUOTED] likes this.
  6. Jan 28, 2016 at 5:15 PM
    #1326
    ThomasMore66
    I don't have the hop issue. Because Dakars? Maybe. Many leaf springs back there squeaking away.
    Biscuits likes this.
  7. Jan 28, 2016 at 7:18 PM
    #1327
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    These are older pics of the URD/Billy Bar.
  8. Jan 29, 2016 at 1:13 AM
    #1328
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    I have the Icon springs on the poverty charged Tacoma and no wheel hop here either. Not that I can remember anyway.
  9. Jan 29, 2016 at 6:39 AM
    #1329
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :eek: That design is aweful. Doesn't allow articulation.
    Which is where the Caltracs excel.
    With a flip kit, the axle plate would essentially be the same as mine. The XR plate. Since I have a "flip kit."
    To reduce the noise, the heim joints could be upgraded to Teflon lined joints instead.
    For those who don't notice wheel hop, something about your leaf springs has changed. Either upgraded aftermarket ones,or updated factory ones because of year model. The early models had extremely soft leaf springs. '05-'08. The slightest terrain change could cause them to warp and undulate,when under acceleration. Swapping to XR leaf springs, took out a MASSIVE amount of wheel hop. The Caltracs did the rest. Before and after.
  10. Jan 29, 2016 at 11:25 AM
    #1330
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    Any of you guys keeping up on Magnusson's re-release of the supercharger? Looking for any information that might be floating around out there and so far I haven't seen anything in the last couple months.
  11. Jan 29, 2016 at 12:18 PM
    #1331
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Don't you have one already?
  12. Jan 29, 2016 at 2:43 PM
    #1332
    WOODEX M.E.
    Corey
    Maine
    I think mos of my noise is actually coming from the rocker-plates themselves rattling against the leaf mounts. Its something i will probably mess around with this summer.
    Those bars compltely changed the feel of the truck, usually i wouldnt be so agressive in promoting stuff but the caltracs and the spec-u headers are some top dog parts that every performance oriented tacoma owner should get.
    Torspd[QUOTED] likes this.
  13. Jan 29, 2016 at 6:25 PM
    #1333
    WOODEX M.E.
    Corey
    Maine
    Well order the Caltracs then custom fab that shit to fit.
  14. Jan 30, 2016 at 12:52 PM
    #1334
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Wrong terminology. Spring under axle flip kit is what I meant.
  15. Jan 30, 2016 at 8:40 PM
    #1335
    WOODEX M.E.
    Corey
    Maine
    @Rock Lobster , This might be a question better suited for the 3rd gen section, but how much axle flip kit can you use and still run 33s? And if not, how much trimming or back spacing will it take to get your mpgs back up to 30?
  16. Jan 30, 2016 at 8:41 PM
    #1336
    TashcomerTexas
    Quoted for incoming shitstorm.
    I don't know if you realized the title of this thread but...the title of this thread. Yeah...
  17. Jan 30, 2016 at 8:51 PM
    #1337
    WOODEX M.E.
    Corey
    Maine
    You obviously missed the humor in the joke. The point was because for the last few months Rock Lobster and many others have been fending off ridiculous questions such as that when talking in a forum that was once seemingly normal.
    Also i have provided plenty of discussion and advice to this thread for people with the trd superchargers and others, in the form of supporting mods. It doesnt matter what the title says.
  18. Jan 30, 2016 at 9:14 PM
    #1338
    WOODEX M.E.
    Corey
    Maine
    Yeah simple solution, buy a manual. Done.
  19. Jan 30, 2016 at 9:19 PM
    #1339
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    HHahahhaahha........ sanitize
  20. Jan 30, 2016 at 9:22 PM
    #1340
    TashcomerTexas
    I saw your comment before you edited in RLs name. Easy now.
