TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Jan 31, 2016 at 5:55 AM
    #1341
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    More
    Plz.
    Torspd likes this.
  2. Jan 31, 2016 at 7:39 AM
    #1342
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Oh....cause of blockage/ignore? That stuff must make it hard to follow threads some times, like a conversation will be going on and the it jumps to somehing else.
    Biscuits likes this.
  3. Jan 31, 2016 at 7:39 AM
    #1343
    WOODEX M.E.
    Corey
    Maine
    Haha what do you want to know?
  4. Jan 31, 2016 at 9:14 AM
    #1344
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Noticed you guys discussing axle hop / roll etc and ways to control it. ATO makes a center mount trac bar like the URD one someone shared. They only make it for the 8.4 diff though. It is heimed and shackled so it still allows full proper articulation and most important does not force your leaf pack into a travel path they do not want to do naturally. Ruff stuff makes DIY kits for trac bars too.
    If you plan on off roading at all or using your rear end travel in any way when you create a trac bar it is critical that you do not create a solid " hinge " that forces the leafs into a set arc. When your axle is mounted to leaf springs it does not travel in a perfect radius as the leafs flex. So, if you create a trac bar that forces the leafs into a set radius it can and will fatigue and break your leafs...ask me how I learned that lesson...
    Rock Lobster likes this.
  5. Jan 31, 2016 at 9:33 AM
    #1345
    ThomasMore66
    Dallas/Fort Worth & Durango
    Yeah! Did you find a helper? I got a guy at work that's willing to help. Just need to get the pulley.
  6. Jan 31, 2016 at 10:18 AM
    #1346
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    Good luck!
  7. Jan 31, 2016 at 10:32 AM
    #1347
    Conumdrum
    Las Vegas
    2014 Tacoma
    Just buy a Raptor, so you won't be Potato.
    WOODEX M.E. likes this.
  8. Jan 31, 2016 at 1:53 PM
    #1348
    ThomasMore66
    I don't like the new V6 raptor. A raptor should have a V8. Twin turbo that.
    Conumdrum likes this.
  9. Jan 31, 2016 at 3:43 PM
    #1349
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Frankenblock will be hibernating on an engine stand soon....
  10. Jan 31, 2016 at 3:57 PM
    #1350
    Conumdrum
    Las Vegas
    2014 Tacoma
    It's still a shorty. Only has 6 cylinders......o_O
  11. Jan 31, 2016 at 4:04 PM
    #1351
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    craptor...... and it should be a compound.... blower for tq and snail for ...... well, does a truck rlly need topend?
  12. Jan 31, 2016 at 6:27 PM
    #1352
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Awwww now the Craptors will be even less of a contest.
  13. Jan 31, 2016 at 7:35 PM
    #1353
    WOODEX M.E.
    Corey
    Maine
    This is my dream for this vehicle. Unrealistic for me financially, but potentioall possibly. Well...maybe not unrealistic, more like irresponsible.
  14. Feb 1, 2016 at 4:17 AM
    #1354
    ThomasMore66
    Oh come on. What we do to our Tacomas is irresponsible to many. It's all relative. I'd like a 1000 hp GTR. Does anyone need that? But I would make it look good...
  15. Feb 1, 2016 at 2:56 PM
    #1355
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    snowmanwithahat likes this.
  16. Feb 1, 2016 at 4:04 PM
    #1356
    benbacher
    Anchorage, AK
    I've already forgotten what the dealer wanted. Wasn't it 4200 for the charger and then another 7-800 for the fit kit?
  17. Feb 1, 2016 at 4:11 PM
    #1357
    benbacher
    Anchorage, AK
    Ah gotcha, that is a bit of a price difference then.
  18. Feb 1, 2016 at 4:21 PM
    #1358
    VolcomTacoma
    Jeff
    NorCal
    Plus crappy Bully dog tuner
  19. Feb 1, 2016 at 4:25 PM
    #1359
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Only 2K for a bullydog! What a deal right? :D
  20. Feb 1, 2016 at 5:23 PM
    #1360
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    pff, turbo is the way to go at that price.
    Torspd likes this.
