TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Feb 26, 2016 at 9:56 AM
    #1501
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    yea it will be fine for what I need since I'm not going to be running a 7th injector, NOS or any of the other crazy shit the XRU guys do. A nice reliable 350 would be perfect and It should get me there
  2. Feb 26, 2016 at 11:58 AM
    #1502
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    X-1 is "better" because it is end user tunable. IMO. Which makes modifying the tune, a quicker endeavor.
  3. Feb 26, 2016 at 12:24 PM
    #1503
    tubbsisland
    Cliff
    Arizona
    Exactly my thought, we've been throwing water/meth kits on all our boosted tundra builds lately too so the ability to tune after the fact turned into a huge bonus. Initially I was a little disappointed in not having the Ucon
  4. Feb 26, 2016 at 3:17 PM
    #1504
    ThomasMore66
    Dallas/Fort Worth & Durango
    Just stick an LS in it.
    ckeene9 likes this.
  5. Mar 8, 2016 at 8:44 AM
    #1505
    ChiveOn
    ChiveOn City Slickin' Redneck, I wear a suit with a mullet
    A BC Boy in Calgary
    2013 MGM DCSB TRD Sport 6spd
    Plasti-Dipped Emblems, Tonnopro Tri-fold toneau cover (for winter use only), AVS in-channel visors, Ultra Gauge, Tepui Kukenam RTT, Muteki Trail Hog 285/70/17, Pop N' Lock, Bilstein 5100's in the front set at .85 with Eibach coils, Bilstein 5100's in the rear with a Toytec AAL. Toytec drivers side spacers, Toytec diff drop kit. All Pro u-bolt flip kit, TJM Compressor (permanently mounted), Custom rack for the RTT over the bed, Tepui Kukenam RTT, Toyota Bed Mat, Cobra 75 WX ST CB Radio, and a lot of gear behind the seats.
  6. Mar 8, 2016 at 6:18 PM
    #1506
    Brianawd
    Brianawd Well-Known Member
    Brian
    Portland OR,
    2015 Tacoma dclb
    Billstein 5100s set at 2.5 in the front,2in AAL in the rear with 5100s
    Any one have any luck with a 2.7 pulley and a fuel pump upgrade with the TRD flash.
    Right now with all the other mods I'm still seeing 10.1-10.3afr
  7. Mar 8, 2016 at 6:23 PM
    #1507
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    Maybe Just a little more.
    My goal with the truck was 13s
    So far my best pass has been a 14.47@94mph.
    So with thinking the 2.7 pulley and IPT valve body. That should put me well into the 13s
    Maybe just the valve body will do it?
  8. Mar 8, 2016 at 6:58 PM
    #1508
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    Between work and ski season don't have much down time.
    The 2.85 pulley makes a big difference. Just wakes up the SC. It's how it should have come.
    I am for sure going to do the valve body soon. The 2/3 shift at full throttle are so slow and delayed I know I'm losing a good chuck of time right there.
    The 2.7 pulley was just a idea as I'm still super rich.
    Biscuits likes this.
  9. Mar 8, 2016 at 7:39 PM
    #1509
    ThomasMore66
    Now I have to have the 2.85. If RL is happy... Wow. Just, wow.
    GT7 likes this.
  10. Mar 8, 2016 at 7:52 PM
    #1510
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    scary, I know. I'm pretty happy with my setup, obviously I want more, but I'm ok now. Switching up to 34s killed alot of my power, can't wait to get some 4.56 gears in there to get my powah back!
  11. Mar 8, 2016 at 7:54 PM
    #1511
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    I want the 2.85 and I've barely had my S/C 2 weeks...
    Biscuits and Torspd like this.
  12. Mar 8, 2016 at 7:55 PM
    #1512
    VolcomTacoma
    Jeff
    NorCal
    Get it. No joke. If you like the SC when you put it on at first, you'll love it even more with the 2.85. Its probably one of the cheapest HP adders around for Hp/$$ gain.
  13. Mar 8, 2016 at 8:08 PM
    #1513
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Do you need to swap the fuel pump for this one?
  14. Mar 8, 2016 at 8:10 PM
    #1514
    VolcomTacoma
    Jeff
    NorCal
    Uhm. That's a highly debated question. I think for the most part no, but its a cheap insurance. I've noticed some power cut outs under really really heavy loads before that I'm pretty sure are fuel pump reaching max output. I've been super lazy about installing mine sitting on the shelf. If you had a full exhaust system and intake and the pulley, then yeah, would probably be a good idea.
  15. Mar 8, 2016 at 8:21 PM
    #1515
    RogueTRD
    Cade
    So. Oregon
    I like the S/C so far but I've been less than impressed, but I come from owning performance cars running a lot more boost. My truck is armored up with heavy ass 33's. It does good for what it is but I could use a little bit more oomph.
  16. Mar 8, 2016 at 8:27 PM
    #1516
    VolcomTacoma
    Jeff
    NorCal
    Ok careful there or you'll fall in with RL. What some people cant seem to understand is, ITS A TRUCK. It's never gonna be as fast as performance cars, especially with the TRD SC, which was designed for reliability and not to blow your engine up. I mean, if you want crazy power, you'd have a URD SC and figure out how to make UCON work, and then you could have like 400+ HP and go fast. with street tires. and an Xrunner. I mean, above all, regearing will get us all back power with oversized tires, the SC can only do so much.
    I mean, I'm probably around 7k in performance mods, just to get maybe another 100 HP to the wheels right now. (Once headers are installed :D). Whenever UCON finally releases I'll grab a 7th injector and Water/meth and the 2.7 pulley and hoping for 350hp to the wheels or so. With a regear I bet that will be super fun. and LT :D. and then I'll be done. Until I blow the engine up and convince the wife I need an LS
  17. Mar 8, 2016 at 8:34 PM
    #1517
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Exactly. The TRD S/C was designed for a little more speed and, for some people more importantly, a little more torque down low to help it out around town or in the woods. The TRD S/C does not make a Tacoma an instant race truck. Think about it. A 2nd gen Tacoma weighs about 400 lbs less than an F150. The F150 has almost 400 HP and 400 ftlbs of torque in the Ecoboost configurations stock and it doesn't qualify as a race truck. That engine makes all it's power down low too just like our TRD S/C. Why would 300 HP and 325 ftlbs of torque make a truck that's fairly close in weight insanely fast?
  18. Mar 8, 2016 at 8:39 PM
    #1518
    RogueTRD
    Cade
    So. Oregon
    Haha, yeah... I'm not looking for anything crazy. If I wanted a "fast" vehicle I wouldn't be driving an armored 4x4 on E rated 33's. :D I just want this baby to be able to get out of her own way and to have a bit more balls for messing around off road. I'm not gonna be running it at the track or racing around. I had a '00 Ford F-150 Lightning, then and '04 WRX STI with 367whp/374wtq, then an '03 Mustang Cobra with 491/517. I just missed the boost. Lol
  19. Mar 8, 2016 at 8:41 PM
    #1519
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    It'll never be a V8 halfton for power. You can get close with lots of mods, but you will fall short of what you could do powerwise with most of the modern trucks that you might see driving around. Not that there is anything wrong with that. The Tacoma can do things offroad that full size trucks can't even touch.
    Biscuits and RogueTRD[QUOTED] like this.
  20. Mar 8, 2016 at 8:44 PM
    #1520
    RogueTRD
    Cade
    So. Oregon
    Yeah, I'm thinking intake and pulley only. It is a definite improvement over stock and in my opinion this is the way these trucks should have come from the factory. I love my Taco and the supercharger made me love it more.
    Biscuits and Sterdog[QUOTED] like this.
