TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Mar 14, 2016 at 2:22 PM
    #1561
    ThomasMore66
    Dallas/Fort Worth & Durango
    That's crazy. I did learn that you can have 1000 hp and a 2 year warrantee... At a cost.
    Biscuits likes this.
  2. Mar 14, 2016 at 3:39 PM
    #1562
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Looks like I'll have to cruise around and check out the scene then. Completely slipped my mind this year. :facepalm:
    At least my turbo and built engine are reuited for this event. Finally.
  3. Mar 16, 2016 at 6:03 PM
    #1563
    Brianawd
    Brianawd Well-Known Member
    Brian
    Portland OR,
    2015 Tacoma dclb
    Billstein 5100s set at 2.5 in the front,2in AAL in the rear with 5100s
    If you have not done the IPT valve body you need to do it. Got mine all done. Truck feels so much better on shifts.
    Biscuits and Torspd like this.
  4. Mar 16, 2016 at 8:53 PM
    #1564
    ThomasMore66
    Better than Level 10?
  5. Mar 16, 2016 at 9:11 PM
    #1565
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    I can't really say. I went with IPT because I have used them in the past for a Auto DSM I had
  6. Mar 16, 2016 at 9:12 PM
    #1566
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    Friday AEM wate/meth kit is going on. Then next week 2.7pulley.
    Biscuits and GT7 like this.
  7. Mar 17, 2016 at 4:54 AM
    #1567
    ThomasMore66
    I'd like to see how you mount the water/meth. I'd like to have it for the summer heat.
  8. Mar 18, 2016 at 11:21 PM
    #1568
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    Well 14.25@94 with a 1.98sixty.
    Only change from last time was the IPT valve body.
    Next and final round 2.7 pulley and water meth.
    Biscuits and SUMOTNK like this.
  9. Mar 19, 2016 at 6:59 AM
    #1569
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That's pretty damn good there. :thumbsup: Do you have any reference from before the valve body upgrade?
  10. Mar 19, 2016 at 10:43 AM
    #1570
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    14.47@94 with a 2.1 sixty was the best before The valve body
  11. Mar 19, 2016 at 2:28 PM
    #1571
    ThomasMore66
    I'm just sayin', URD has the worst website when it comes to payment information.
    Ordered the 2.85 pulley.
  12. Mar 19, 2016 at 2:42 PM
    #1572
    ThomasMore66
    Did the Lobster get banned? WTF?
  13. Mar 19, 2016 at 2:43 PM
    #1573
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Om
    Check your junk box for their emails as well. You won't get anything for at least a few days if not a week and then suddenly...ORDERED/CONFIRMATION/SHIPPED/TRACKING like a week or two later. Or more.
  14. Mar 19, 2016 at 2:44 PM
    #1574
    VolcomTacoma
    Jeff
    NorCal
  15. Mar 19, 2016 at 2:45 PM
    #1575
    ThomasMore66
    I wonder what he did? Posted another racing video?
  16. Mar 19, 2016 at 2:46 PM
    #1576
    VolcomTacoma
    Jeff
    NorCal
    I can neither confirm nor deny any allegations against said 'Rocklobster'. No, really. I can't. The mods love him still. I'll get a ban.
  17. Mar 19, 2016 at 2:51 PM
    #1577
    ThomasMore66
    He's got the strike-through. Hope it's not permanent.
    I've been banned from certain threads a few times...might have been the alcohol...
  18. Mar 19, 2016 at 2:53 PM
    #1578
    VolcomTacoma
    Jeff
    NorCal
    Yeah I've been banned from this thread because of him multiple times. No sweat. But the line through the name is pretty bad. Possible a couple days to a week. Or hopefully permanent! But I won't hold my breath. He was allowed to come back after getting his Whippersnapper name banned.
  19. Mar 19, 2016 at 2:56 PM
    #1579
    ThomasMore66
    Sometimes when the threads get stupid, and it's late at night, and there may/may not have been some imbibing going on, my inner troll will come out. Those 3rd gen people...
    Sterdog likes this.
  20. Mar 19, 2016 at 2:58 PM
    #1580
    VolcomTacoma
    Jeff
    NorCal
    Dude, preachin' to the choir. Except I try to stay out of the 3rd gen forums. To much stupid going on. Sometimes I accidentally click a link on the home page, thinking to myself "I can help this person! I know the answer to that!" and then there's 100 pages to the thread of inane babble and 4 posts in I want to shoot myself. #mistakesweremade
