TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Jul 25, 2013 at 5:43 AM
    #141
    Large
    Large Red
    There was hardly any low end gains with my S/C. Tow a trailer in "4" on the highway at 70 mph is a different story (running 3k rpms) but also getting <10 mpg. You are right about the bang per buck for a bolt on, and unless you want to do some R&D it's the right choice, but I'd still get a turbo over the S/C given the chance again.
  2. Jul 25, 2013 at 7:42 PM
    #142
    Beers
    Beers Well-Known Member
    Colorado
    12 TRD OR
    I would think that is better than nothing. My advice would be to negotiate the install cost up front then when it comes time to do the install, drop it off and tell them not to rush. Let them take as long as they need to do the job correctly. By negotiating the cost up front you won't have to worry about excessive charges and you give them all the time they need. In the end it may take longer but you would pay a lower hourly shop rate and still have a good job. This isn't something you want the installation rushed on.
  3. Aug 1, 2013 at 12:50 PM
    #143
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    In Canada you are lucky to get it for under $6000 installed, the dealers cost is around $4500 for just the blower.
    Regardless, I'll be blown in less than a week!
  4. Aug 4, 2013 at 12:43 PM
    #144
    RadiantS
    RadiantS New Member
    RR SRunner
    TRD
    TRD S/C is a blast - low maintenance and reliable too, excellent value
  5. Aug 4, 2013 at 12:48 PM
    #145
    josepenajr
    josepenajr Well-Known Member
    Laredo , Texas
    13 Texas Edition Double Cab
    3 inch lift, Painted black rims, black bull bar, black bug deflector, Black PlasTi Dipped Emblems, 275/70/17 Tires
    do they have one for a 2013 texas edition ? or has to be a TRD??
  6. Aug 4, 2013 at 1:55 PM
    #146
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That doesn't matter.
  7. Aug 4, 2013 at 2:09 PM
    #147
    josepenajr
    Laredo , Texas
    thanks
  8. Aug 4, 2013 at 2:55 PM
    #148
    Corndawg
    Corndawg Well-Known Member
    Corey
    Utah
    2007 double cab TRD off road Radiant Red
    2.5 inch pro comp lift Cobra XRS 9745 Detector 15 band scanner Pioneer DEH-P6900UB Python 991 remote start/ security. Tinted license plate covers Fog Light Mod PIAA Extreme White 4000K Replacement bulbs Red LED Dome and Map lights LED replacement tail light bulbs Black Weather Tech Floor Liners front and rear
    i have 285/70/17 and 66,555 miles on my 2007 trd offroad double cab. will the 285s rob power considering the
    TRD S/c
  9. Aug 4, 2013 at 6:05 PM
    #149
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Yes but the power increase will still be definitely noticeable.
  10. Aug 4, 2013 at 6:12 PM
    #150
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    especially with the 2.8 inch pulley and a fuel pump from Dezod :)
  11. Aug 4, 2013 at 7:13 PM
    #151
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    :thumbsup:
    Approx 1 more week buddy
    Plus I found out buttonwillow has a dynojet.
    Only about 80 miles away........ 7s only racing
    When Toyota claims 303 HP with blower, I assume its crank yes?
  12. Aug 4, 2013 at 7:40 PM
    #152
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    correct at the crank.
  13. Aug 4, 2013 at 7:57 PM
    #153
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Thanks mang
  14. Aug 4, 2013 at 8:00 PM
    #154
    elsenordave
    elsenordave HaoleBilt
    Dave Smith
    Blown 2013 NBM DCSB Sport
    AFE CAI TRD Exhaust TRD Supercharger 3" Cornfed Spacer 2" Toytec AAL
    :D
  15. Aug 5, 2013 at 4:31 AM
    #155
    memario1214
    Colton
    Missoula, MT
    That's the truth.
    My truck is making noise again... :pout: Seems to be a big exhaust leak or something maybe? I'm not sure yet but I leave it sit for a few days at the airport and that's what happens.
  16. Aug 12, 2013 at 8:34 AM
    #156
    ATHiker
    ATHiker Well-Known Member
    Tom
    Tennessee
    15 Tundra DC 4X4 SR5 OR 5.7L
    For those that have installed a SC. Is a CAI and / or exhaust modification required? Beneficial? Just wondering if I start down the SC path, how far does it lead?
  17. Aug 12, 2013 at 8:44 AM
    #157
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Required no. Beneficial, yes.
  18. Aug 23, 2013 at 12:12 AM
    #158
    S1000RR
    S1000RR Well-Known Member
    2013 TRD Supercharged Sport
    Got to agree. The Y Pipes make a huge different up top as well.
  19. Aug 23, 2013 at 12:13 AM
    #159
    S1000RR
    How much PSI are you TRD guys running? I'm hitting around 12 psi at night. =]
    Running the 2.8 URD Stealth, but I believe it went up a couple PSI after I installed the Y Pipes.
  20. Aug 23, 2013 at 4:39 AM
    #160
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What elevation are you?
    Also, increasing exhaust, or intake efficiency of flow will decrease the psi reading.
