TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Mar 20, 2016 at 12:52 PM
    #1601
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    On Yotatech or something, a person claimed to have done a datalog and the stock pump was running 97% duty cycle and AFR drops at higher rpms. Really, an upgraded pump is one of the cheapest mods and can easily be done in a couple of hours. I should add, on a brand new truck, my tank had A LOT of plastic shavings and dirt in it and stuck on the sock.
    12TRDTacoma likes this.
  2. Mar 20, 2016 at 12:56 PM
    #1602
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Was those datalog 97% duty cycles with an NA or a supercharged tacoma?
    Regardless, this statement and information only solidifies what I am talking about even further. Ideally, you never want to exceed over 90% duty cycle as that remaining 10% is more of a safety net.
  3. Mar 20, 2016 at 1:01 PM
    #1603
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Well I heard from another guys friends girlfriends brother in law that the pump is fine until you start upgrading stuff.
    Biscuits, Sterdog and Torspd like this.
  4. Mar 20, 2016 at 1:16 PM
    #1604
    gottaToy
    JJ
    1985 Moped
    My rousch kit on another vehicle runs about 47%duty cycle, so I had planned on the pump change early on because regardless of the pulley size, the pump has to be pushing it's limits from the factory. I think 12TRDTacoma's fuel pump experience justifies a very small expense compared to all the other crap we spend money on.
    Biscuits likes this.
  5. Mar 20, 2016 at 1:19 PM
    #1605
    VolcomTacoma
    Jeff
    NorCal
    Ok whatev lol. Agree to disagree. I'm not gonna have this same conversation every 3-6 months. A certain ostrich will show up if we keep it up, and then mods get involved...
  6. Mar 20, 2016 at 1:33 PM
    #1606
    Brianawd
    Brianawd Well-Known Member
    Brian
    Portland OR,
    2015 Tacoma dclb
    Billstein 5100s set at 2.5 in the front,2in AAL in the rear with 5100s
    Anyone have the upgraded pump sitting around and could post up the part#
    I have 2 255 pumps sitting around one of them should work
  7. Mar 20, 2016 at 1:36 PM
    #1607
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Trying to determine which is the HP?
  8. Mar 20, 2016 at 1:45 PM
    #1608
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    Both are 255hp
  9. Mar 20, 2016 at 1:46 PM
    #1609
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    One has intake and outlet on the same side. The other is intake on one side and outlet on the other
  10. Mar 20, 2016 at 1:54 PM
    #1610
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You're a straight fool Jeff. Lol. Well what else could I expect from IN THE NAVYYY!!!!
    It is a wise decision and definitely a good preventative to keep you from getting stranded on the road all of sudden with or without warning.
    Dude, have you seen how small the stock pump is? I am surprised that shit is able to make the truck run with how tiny it is. Tell you wht, if you don't believe me, I will bring it to the next mod day or wheeling trip just to show you how shit it is.
    Denso or not, you can only condense things to be so small to the extent that they will not work properly and be able to keep up with the demands that it is expected to keep up with.
    Get a AEM 320LPH 50-1200 greentop. I have had excellent results and an overall experience with mine. It is E85 capable as well if you choose to go that route at aome point, you are set.
    You mean 255LPH? Lol.
  11. Mar 20, 2016 at 2:12 PM
    #1611
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    No need to buy a new pump when I have 2 sitting here. I'm sure one of them will fit.
    Also don't need that big of a pump. If I can make 500awhp on my evo running e85 using a 255. It should be more then enough Pump for my Tacoma.
  12. Mar 20, 2016 at 2:16 PM
    #1612
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    Oh and no I meant 255hp
    You can get 2 diffrent pumps
    255LP and 255HP
    They may have changed it up over he years but the HP =high pressure
    LP=low pressure
    Biscuits and 12TRDTacoma like this.
  13. Mar 20, 2016 at 2:25 PM
    #1613
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I was just saying reliability wise, my AEM pump has been top notch.
  14. Mar 20, 2016 at 2:30 PM
    #1614
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    Thanks for the info.
    I have been lucky over the years and never had a issue with a walbro
    12TRDTacoma[QUOTED] likes this.
  15. Mar 20, 2016 at 2:31 PM
    #1615
    gottaToy
    JJ
    1985 Moped
    Walpro? If so, they would both be 255lph (high pressure) but one has offset inlet/outlet. My memory sucks, but I think the ones for the toyota are NOT offset. The hp is a marketing gimmik. I would think you could use either as long as they don't interfer with the valve in the bucket that allows fuel to flow in.
  16. Mar 20, 2016 at 2:44 PM
    #1616
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah the Toyota ones are inlet and outlet in the same spots. Not offset.
  17. Mar 20, 2016 at 2:45 PM
    #1617
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    The hp vs LP was not a making gimmic.
    as demand on the pump increased the LP dropped off. So the HP was interduced. I have logged both pumps and at anything over 25psi on the LP pressure started dropping rapidly.
    The HP was able to better keep up with demand.
  18. Mar 20, 2016 at 2:51 PM
    #1618
    gottaToy
    JJ
    1985 Moped
    I don't know:rolleyes: I went AEM
  19. Mar 20, 2016 at 3:07 PM
    #1619
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I wonder with all this fuel pump talk how long it will be before @Ostrichsballsak shows up
  20. Mar 20, 2016 at 3:09 PM
    #1620
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Brainawd is correct. Walbro offers two versions of the 255lph pump. Back years ago when I didn't know any different I had ordered a 255lph pump kit through URD. Ran great. Until I added boost pressure to the fuel pressure regulator. At that time years ago, URD only offered the non High Pressure version. As no one was increasing their fuel pressure with a boost reference.
    Fast forward to when I made my front mount turbo kit, and had the ProEFI for tuning, we noticed some dips on the dyno graph. Pulled up the datalog, and at only 10 psi boost, which also put an additional 10psi pressure on the fuel system & pump, it was not able to keep up. Plain as day in the datalog.
    Shared that data on XRU and boom. All sorts of new pumps that could handle increased fuel pressures were available through URD.
    All pump manufactures show flow output versus pressure increase on X-Y graphs. Walbro's non HP 255 only does well with static fuel pressure.
    Brianawd, use the pump with inlet on bottom and outlet on top. :thumbsup:
