TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Mar 28, 2016 at 12:39 PM
    #1761
    ThomasMore66
    Dallas/Fort Worth & Durango
    Most of the components for the press-on tool.
  2. Mar 28, 2016 at 12:57 PM
    #1762
    ThomasMore66
    Anybody tried cooling the shaft with dry ice or N2?
  3. Mar 28, 2016 at 1:08 PM
    #1763
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That was a fun mini mod day man! I agree, two people doing it is better and way more beneficial than fighting with it.
    Biscuits likes this.
  4. Mar 28, 2016 at 1:09 PM
    #1764
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No need for it. Room temp will suffice.
  5. Mar 28, 2016 at 1:25 PM
    #1765
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  6. Mar 28, 2016 at 1:53 PM
    #1766
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    There was a guy somewhere on this forum that flipped an air duster upside down and sprayed the shaft until it was icy cool. He said that it really helped, but he is also the only person I've ever seen try that
  7. Mar 28, 2016 at 3:21 PM
    #1767
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Its not gonna help. You're not gonna cool down the shaft enough to get it contract enough, and the heat of the pulley and the cold of the shaft would just work against each other quicker. Follow the instructions URD sends along and it works perfectly.
    12TRDTacoma likes this.
  8. Mar 28, 2016 at 3:22 PM
    #1768
    VolcomTacoma
    Jeff
    NorCal
    Also, do it after the SC is installed...:rofl:
  9. Mar 28, 2016 at 3:32 PM
    #1769
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    I bought a toaster oven from wally world for $24.99, through the pulley in it next to the truck @400 degrees. Removed the old pulley, installed the lubed up install tool on the shaft, removed the baked pulley and set it on the install tool, put the washers/bearing on, screwed on the nut, held the tool with a wrench and screwed the nut with a ratcheting wrench. It went all the way on pretty easy. Had maybe 20-30 minutes in the oven. I spent more time screwing with a 3 jaw HF puller to remove the old pulley than anything else. I threw it away and used a bar puller instead.
  10. Mar 28, 2016 at 3:54 PM
    #1770
    gottaToy
    JJ
    1985 Moped
    I had the problem @crashnburn80 noted in his write up. If I started the set screw in the SC shaft, the tool would screw it farther in the shaft rather than going in the tool and vice versa if I installed it in the tool first. Couldn't ever guarantee it was somewhat even in both parts? Gadget should have sent longer set screws. Partly why I installed the tool on the shaft, so I could use a really small screwdriver to hold the set screw in place to make sure it was somewhat evenly screwed in to the shaft and the press tool. Plus when I was practicing, I found it easier and less handling of the hot pulley. I never need a strap wrench as it went on so easy.
  11. Mar 29, 2016 at 1:11 PM
    #1771
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Agreed that thing was total garbage. The thick claws did not fit well without interference on the SC body and the tool ended up breaking anyway, twice. The Craftsman unit I used worked like butter.
    Agreed on the longer screws. One possibility would be to put a dab of serviceable locktite on the screw before putting it into the tool and let it dry. This would ensure that it does not further thread into the tool and an equal amount of threads go into the tool and into the snout.
  12. Mar 29, 2016 at 1:15 PM
    #1772
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Because HF....
  13. Mar 31, 2016 at 6:42 PM
    #1773
    VolcomTacoma
    Jeff
    NorCal
    Damn, got quiet in here...
  14. Mar 31, 2016 at 6:44 PM
    #1774
    VolcomTacoma
    Jeff
    NorCal
    Installed my URD fuel pump upgrade finally. AFR is now down around 10.2 at WOT, used to sit about 10.9-11.2. No more flat spots in the power band either. Also figured out why Im topping out at 7.5 boost on cold mornings, lots of exhaust leaks from the clamps URD provides with their Y pipe and exhausts. Guess I'm getting that bitch welded so I can see 8 PSI again someday.
  15. Mar 31, 2016 at 7:22 PM
    #1775
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    They would need to be some insane leaks to cause that type of boost. If that .5lbs of boost is cause by back pressure you won't gain anything by getting your gauge to read higher.
    My truck on the stock exhaust and 3.0 pulley read 8+ lbs of boost. Put in the Urd spec-u exhaust and it dropped to where it was supposed to be 6ish lbs. truck didn't lose any power in fact it gained power. Increase in boost was caused by too much back pressure which isn't a good thing.
    Biscuits, 12TRDTacoma and Torspd like this.
  16. Mar 31, 2016 at 7:27 PM
    #1776
    VolcomTacoma
    Jeff
    NorCal
    Ohhhhhh weird. Well, I saw 8 PSI when I first had everything bolted on, fast forward now about 6 months or so and while I was up under the truck I saw pretty much all of the joints for the exhaust and Y pipe have soot spots around the connections. Nowadays I usually hit about 7 lbs and early morning if I hit it hard in 4th I can see 7.5 lbs.
    TRD SC
    URD Y Pipe
    URD Mark III 3" exhaust
    URD 2.85 pulley
    AFE Stage II SI ProDry Intake
    URD Fuel Pump
  17. Mar 31, 2016 at 9:44 PM
    #1777
    Brianawd
    Brianawd Well-Known Member
    Brian
    Portland OR,
    2015 Tacoma dclb
    Billstein 5100s set at 2.5 in the front,2in AAL in the rear with 5100s
    on the 3.0 pulley I was seeing about 5-5.5psi
    2.85 pulley maybe 7psi on a cold morning mostly around 6-6.5psi
    The 2.7 7-8psi
    Torspd likes this.
  18. Mar 31, 2016 at 9:50 PM
    #1778
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    The max Ive seen on 2.85 pulley is 6.5, @Brianawd did the switch to the 2.7 really make a difference?
  19. Mar 31, 2016 at 9:53 PM
    #1779
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I used to hit 6.5 also before swapping out the intake. Your intake is your bottleneck. Replace it out with the URD or the AFe intake. You will hit 7.5-8 lbs of boost after replacing it no problem using the 2.85 pulley.
  20. Mar 31, 2016 at 9:54 PM
    #1780
    12TRDTacoma
    Rob
    Concordia
    Boosted
    About goddamn time slacker.
    Biscuits and Torspd like this.
