TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Aug 23, 2013 at 4:53 AM
    #161
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Seriously. Don't know if you have Lucario Runner's before and after dynos with the URD Y, but it is very impressive!
  2. Aug 23, 2013 at 5:43 PM
    #162
    tank3105
    tank3105 Well-Known Member
    Houston
    13 baja T/X edition supercharged
    Supercharged.
    Yes, I think so. The most best mod is a wideband gauge if you want a healthy truck.
  3. Aug 23, 2013 at 5:53 PM
    #163
    lemon177
    lemon177 Well-Known Member
    Matthew
    Oahu
    09 tacoma 4x4 sport pyrite mica
    TRD supercharger, URD 2.85" stealth pulley, TRD exhaust, TRD intake, DTLT headers, URD y-pipe, TRD boost gauge, PLX DM100 touch with OBDII and SM-AFR modules, 885 OME 3", Icon UCAs, Satoshi grill, Solid rear window, SCS stealth 6, 285/75/17 toyo AT2.
    what type of gauge are you reading psi from? digital?
    might be picking up a bad signal
  4. Aug 23, 2013 at 7:56 PM
    #164
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What is your gauge doing?
  5. Aug 28, 2013 at 3:38 AM
    #165
    S1000RR
    S1000RR Well-Known Member
    2013 TRD Supercharged Sport
    It's a boost gauge, it doesn't pick up a bad signal, lol.
  6. Aug 28, 2013 at 3:40 AM
    #166
    S1000RR
    Basically Sea level here in Seattle. Also it was at night. During the day it's a couple psi lower.
  7. Aug 28, 2013 at 8:08 AM
    #167
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    I've got the 2.85 stealth pulley and hit 7.5 PSI on my boost gauge. AFE CAI and TRD Catback at the moment. I'm around 700 Ft elevation. 12 PSI seems high for the 2.8 pulley unless you are spinning some major RPM. Granted this video below is at 90° ambient outside plus humidity, your cooler air may be helping.
    http://youtu.be/66FclLTElZU
  8. Aug 28, 2013 at 12:39 PM
    #168
    tank3105
    Houston
    Supercharged.
    Agreed, I'm hitting the same thing with volant cai and 2.85. 10.2 on stock fuel pump.
  9. Aug 28, 2013 at 3:24 PM
    #169
    lemon177
    Matthew
    Oahu
    There's a mechanical gauge and an electrical gauge (plx brand for example). so if you have anthe eletrical gauge and didn't properly get a signal you'd be getting a bad reading. Otherwise, it would really take alot to git anything over 10psi...surely more than just the 2.85 pulley.
  10. Aug 28, 2013 at 3:44 PM
    #170
    Corndawg
    Corndawg Well-Known Member
    Corey
    Utah
    2007 double cab TRD off road Radiant Red
    2.5 inch pro comp lift Cobra XRS 9745 Detector 15 band scanner Pioneer DEH-P6900UB Python 991 remote start/ security. Tinted license plate covers Fog Light Mod PIAA Extreme White 4000K Replacement bulbs Red LED Dome and Map lights LED replacement tail light bulbs Black Weather Tech Floor Liners front and rear
    on case of shitty? how bad will mpg be with S/c v6 and 285 70/17.?? i drive mostly 55mph everywhere i go on high way unless im in a hurry. i drive like there is an egg in the accelerator..? trying to decide if i should do it. or wait and buy a new tacoma in 2 years
  11. Aug 28, 2013 at 5:56 PM
    #171
    KingKoda
    Palmetto
    '12 TRD.S DCSB 4x4
    From what I read there....wait. You're too focused on MPG instead of what you want the truck for.
  12. Aug 28, 2013 at 6:59 PM
    #172
    SkottK62
    SkottK62 Well-Known Member
    So for another noob question is the ideal to have the psi low as possible? I understand elevation plays a part but I'm guessing lower psi is better?
  13. Aug 28, 2013 at 7:50 PM
    #173
    Corndawg
    Corey
    Utah
    i have a basic mod list..
    consisting of complete stereo system upgrade subs etc
    magnaflow exhaust
    intake
    tint darker.
    trd supercharger is in debate.
    seat covers.
    i allready have weather techs.
    maybe new grill. and offroad front or rear bumper. if i get in fendar bender.
    possibly LT kit. or mid travel.
  14. Aug 28, 2013 at 9:01 PM
    #174
    TuckyTaco
    TuckyTaco Member
    Brad
    Mesa, AZ
    2000 Yota Taco
    All-pro full leaf packs, Bilstein rears, Fox 2.5 w/Resi's up front with all-pro UCA's.
  15. Aug 29, 2013 at 3:09 AM
    #175
    S1000RR
    The cooler air always helps in higher psi. :D
    Here is a video I took, temps were in the lower 70s this time. Still hitting 9psi.
    http://youtu.be/YSxQekLe548
  16. Aug 30, 2013 at 11:36 AM
    #176
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Is the TRD Supercharger safe on CA crap gas?
  17. Aug 30, 2013 at 12:07 PM
    #177
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    I gas up at a variety of stations with no problems , 10k miles on my SC. 91 octane in Nor Cal.
  18. Sep 2, 2013 at 11:19 PM
    #178
    Voodoo Rufus
    Bakersfield, CA
    I see you have the TRD intake also. I'm guess it works ok with the charger and is CARB legal as well?
  19. Sep 13, 2013 at 6:39 PM
    #179
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Hahaha :rolleyes: You notice a difference in pick up after installing the FN wheels?
  20. Sep 18, 2013 at 11:59 AM
    #180
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
