TRD supercharger
Discussion in 'Performance and Tuning' started by JMITCH08, Dec 3, 2007.
  1. Apr 19, 2016 at 8:14 PM
    #1961
    ThomasMore66
    Dallas/Fort Worth & Durango
    Finally got my gauges from Speedhut. Time. That's what I need now.
    VolcomTacoma likes this.
  2. Apr 19, 2016 at 10:12 PM
    #1962
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I like my Speedhut Boost gauge, but wanted a digital AFR so I wouldn't have to look at an analog gauge to try to read my A/F lol. AEM Uego works great for that. I'm slightly considering a Lotek gauge pod for fuel pressure and maybe Water/meth but It looks so ricey to me, ugh.
  3. Apr 20, 2016 at 4:01 AM
    #1963
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    Love my AEM Uego. Having the digital readout with the colored "gauge" around the outside makes it easy to read at a glance.
  4. Apr 20, 2016 at 9:07 PM
    #1964
    ThomasMore66
    I got a digital AFR from Speedhut that uses the AEM Uego controller. Now I just need to figure out the wiring.
  5. Apr 20, 2016 at 9:14 PM
    #1965
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    You should check out the aem failsafe. I don't use any of the data logging or protection features, but it does monitor both air/fuel and boost with one gauge. I've run uego on all my other cars and it was great. But this allows me to cover both with only one gauge
    JuanitoBonito likes this.
  6. Apr 25, 2016 at 8:56 AM
    #1966
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    But he's still lurkin. RL yesterday
    http://youtu.be/ZHwwWX9y1uA
  7. Apr 25, 2016 at 10:27 AM
    #1967
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    cory02taco and Torspd like this.
  8. Apr 25, 2016 at 10:36 AM
    #1968
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    We only did it so he would feel better. He's been in a deep depression since his ban.
    mahaloTaco, Torspd and GT7 like this.
  9. Apr 25, 2016 at 10:49 AM
    #1969
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Hell of a dust trail. Looked freaking cool. :thumbsup:
  10. Apr 25, 2016 at 10:52 AM
    #1970
    eon_blue
    Azusa, CA
    Yeah I never get over 5.5 maybe 6 psi with my stock TRD s/c setup.
    Question: I've been considering adding the smaller URD pulley, is it a fairly easy install? Or does the supercharger have to come off to switch out the pulleys? I'm new to the forced induction game, just got this truck last month. Definitely loving it so far
  11. Apr 25, 2016 at 7:59 PM
    #1971
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Here is my write up:
    https://www.tacomaworld.com/threads/urd-2-85-stealth-supercharger-pulley-install.416267/
    Easy enough with 2 guys, assuming your tool doesn't grenade into your engine bay like mine did.
    eon_blue[QUOTED] likes this.
  12. Apr 25, 2016 at 8:02 PM
    #1972
    eon_blue
    Azusa, CA
  13. Apr 25, 2016 at 8:08 PM
    #1973
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I had a shop do it. I got the pulley new from someone on craigslist. So paying the shop and buying the pulley was less then the pulley and the tool.
  14. Apr 25, 2016 at 8:12 PM
    #1974
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Temp delta is your friend for the install. I bought mine off another TW member and specifically waited for winter to install so the truck would be colder.
  15. Apr 26, 2016 at 4:33 AM
    #1975
    ThomasMore66
    Finally have my gauges and the AFR controller. Thinking hard about urd's y pipe.
  16. Apr 26, 2016 at 3:55 PM
    #1976
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Do it......you won't regret it.
  17. Apr 27, 2016 at 9:19 AM
    #1977
    ThomasMore66
    Why are the back two cats on there in the first place? Do the front ones not do the job?
  18. Apr 27, 2016 at 11:52 AM
    #1978
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    The way I was made to understand it......the rear 2 cats are pointless and the rear 2 sensors are just flow sensors and are not monitored by the computer.....as opposed to the 2 front o2 sensors.
    I was worried about doing away with the rear cats and sensors as far as throwing codes. I was completely reassured it would not. .......to this day, I have not had a problem what so ever and am totally glad I swapped in the y-pipe.
    Edit.....one extra thing I did and glad as well was I had the one tip welded on the pipe. You'll see when you get it, it actually comes in 2 pieces. Shipping purposes i believe. I rather would have it welded making it one piece as opposed to using clamps.
  19. Apr 27, 2016 at 4:00 PM
    #1979
    VolcomTacoma
    Jeff
    NorCal
    Yeah i need to have mine welded uo along with my exhaust when I get the truck back. Probably just gonna drop at an exhaust shop and have them install headers and weld up the whole exhaust
  20. Apr 27, 2016 at 4:21 PM
    #1980
    spithead051
    Patrick
    Fairfax, VA
    For those of you wanting to install a winch after installing a supercharger, I found an easy solution for the intercooler pump that needs relocation. This doesn't require draining the intercooler system and only involves one modification on the truck
    1. Unbolt the intercooler pump from the hood support bracket
    2. Using a grinder, cutoff wheel, etc. remove all of the material below the welded nuts that the intercooler pump was bolted too and sand the edge smooth
    3. Flip the clamps so they line up with the mounting nuts and the pump is under the core support
    4. Bolt the pump back onto the hood support bracket and make sure the pump is fully under the radiator core support
    5. Enjoy a beer
    Here's a picture of the finished product, I failed to grab some during the process but figured having the steps written down would help someone!
