Trd supercharger
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nefba, Mar 21, 2017.
  1. Mar 21, 2017 at 12:18 PM
    Nefba
    Nefba [OP] Member
    Nicl
    2006 black tacoma trd
    I have a 06 tacoma with 180k on it and im wanting a little more pwee behind it Does anyone know if putting a supercharger would be worth it at this point? My engine and tranny are well taken care of. Never had to fix anything in either of them. Would puting a supercharger do anything major to hurt my tranny or engine. My taco is programmed woth a bullydog also
  2. Mar 21, 2017 at 2:41 PM
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    Should be just fine with a supercharger, but will really depend on how you drive it after it's installed
  3. Mar 21, 2017 at 2:47 PM
    joshj808
    joshj808 Active Member
    2010 Silver Tacoma TRD Sport
    None
    What exactly can an aftermarket tuner do to an N/A 4l v6?
  4. Mar 21, 2017 at 2:53 PM
    2015 TRD Sport
    South Carolina
    2021 TRD Pro
    Pretty much nothing, but a nice dent in your wallet.
  5. Mar 21, 2017 at 8:07 PM
    Nefba
    Nefba [OP] Member
    Nicl
    Not true. I gained enough hp for you to feel it and i have a much stronger shift. It also used to manage fuel millage aswell so its not like i have it just to dent my wallet
  6. Mar 21, 2017 at 9:57 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Lots of issues with bulldog programers. Many have seen their programed tunes go back to stock settings without their knowledge. It's a good programers for diesel but for reason it really sucks on the Tacoma. I'd run the UniChip before I run the bully dog. Heck the Map ecu3 would be a better system then the bully dog tuner. Also the URD Ucon a stand alone system would be the best for your year truck.
    I'd get a compression test just to check the condition of the rings since they are 180k miles on them. Also leak down test would be another good insurance to make sure the valves, valve seals, etc.... are in top conditions for force induction.
    If all are good boost the motor. The transmission it would be a good idea to change out the transmission fluid since again 180k miles on the tranny and heat is the # 1 killer of transmission. For the most part the 5spd auto transmission is pretty stout since it was designed for the 4.7L V8 engine in the 4Runner that also shares the same tranny with the 4.0L V6. Hope that helps you out.
  7. Mar 22, 2017 at 7:56 AM
    Nefba
    Nefba [OP] Member
    Nicl
    A lot of my family has bullydogs. And none have had problems out of them and niether have i. And thank you very much for the help
