TRD supercharger
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by TMFF, Sep 23, 2023.
  1. Sep 23, 2023 at 3:48 PM
    TMFF
    TMFF [OP] Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    Located in Thornton, CO
    $3K Gen 1 TRD supercharger for 3.4L V6 that came in Tacoma’a, 4Runners, and Tundras.
    The rear bearings and nose cone were replaced 10K ago everything spins and works as it should.
    Makes 6psi at 5500 elevation with the 2.1” pulley.
    Included is the complete kit to install this on a 3.4 along with many extras and spare parts.
    Tensioner with the mounting bracket.
    The longer bolts to bolt to the lower intake.
    1 good used belt and a new spare
    All 3 throttle cable brackets
    4 different pulleys, installed in a 2.1”, 2- stock pulleys and the spare snout has a 2.0 installed. Aftermarket pulleys are made by pulley boys.
    The spare nose cone needs to be rebuilt
    Both nose cones have a 1/2 pipe plug installed for easy oil changes.
    1- 8oz bottle of intense supercharger oil
    Napa 180* thermostat, new.
    Spare nose cone bearings, 2.
    2 new nose cone seals, Viton for upgraded seal. One is currently installed.
    Gasket maker for the nose cone if it’s ever removed.
    Paper template to cut the timing cover.
    Small brackets for the wiring harness and dipstick relocation.
    The boost elbow was recently resealed with new O rings and RTV.
    Original paperwork from TRD/Toyota
    Install instructions and warranty information
    2 “supercharged” emblems
    3 “TRD” emblems
    TRD CARB sticker
    This is a complete kit! At most all you will need is some 1/8 fuel line for the FPR and some 3/8 fuel line for the EVAP/ valve cover hoses and you’ll need a new throttle body gasket, the O shaped one, stock is a D shape.
    Shipping available at buyer’s expense.
    IMG_0343.jpg IMG_0345.jpg IMG_0347.jpg IMG_0351.jpg IMG_0352.jpg IMG_0349.jpg IMG_0348.jpg
    Jon64l likes this.
  2. Sep 24, 2023 at 10:12 AM
    highvelocitytaco
    highvelocitytaco Well-Known Member
    queens ny
    1996 2.4 tacoma 2wd
    Great deal here. Wish I could just get better mpg and I would be jumping on this.
  3. Sep 24, 2023 at 1:10 PM
    02hilux
    Planet: EARTH
    If they're going for that much, this make me want to take my 2nd gen off and sell for $4,500 complete with HSL 2.1 steel pulley, URD 7th injector, URD tensioner pulley, JBA header, TRD cat back and do a 2uz swap
