TRD SuperChargers Owners need help please!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ninja89, Jun 10, 2015.
  1. Jun 13, 2015 at 8:47 PM
    #61
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    What are your reason or reasons for getting the TRD S/C? Is it purely just because they are going to stop making them or do you need the extra power for towing and or higher elevations? Or is it just for the fun factor? I purchased mine because I knew I wasn't going to spend 4K on a lift, wheels & tires, amour, winch, lights etc. for offroading because I would never actually use any of it to its full potential. Now as for the S/C I used it to its full potential very time I drive it.
    :burnrubber:
    6xchamps and techbill like this.
  2. Jun 13, 2015 at 8:58 PM
    #62
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Get a TRD SC. It stays under warranty with Toyota which is nice. And WHAT!?! Why is toyota getting rid of the supercharger?!?
  3. Jun 13, 2015 at 9:05 PM
    #63
    SYTFUxMBRProjects
    SYTFUxMBRProjects Instagram: b00sted_b18c5
    Mark
    San Leandro
    2006 Super White Tacoma TRD-Sport Supercharged
    Don't think about it, just do it. Think about it, and you may never get one. Get one NOW, then you can think about your wise choice of spending the loot on one, LOL.
  4. Jun 13, 2015 at 9:18 PM
    #64
    Dubie220
    Dubie220 Active Member
    NorCal
    14 DCLB 4X4 Sport
    I'm looking to buy one also. I have a 2014 ..... Im seeing them listed as 2012-2013. Is there a difference between 2013 and 2014? Just asking because ive seen you guys talking about different plugs on the URD s/c for different years.
    Anyone found a good deal on where to buy one?
  5. Jun 14, 2015 at 12:17 AM
    #65
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    Here is my $.02.
    If you have never supercharged a truck then go for it. I did it once and it was fun but in the end not worth it. Its expensive and affects reliabilty.
    On my recent Tacoma I decided to go with a re-gear instead. Its better for towing with larger tires and has plenty of fun factor with mashing the pedal.
    RJM
    ninja89[QUOTED][OP] likes this.
  6. Jun 14, 2015 at 6:40 AM
    #66
    Ninj
    Ninj Well-Known Member
    Ninja
    New Hampshire
    2011 Super White TRD Off-road SR5 6 Speed
    URD True Cold Air Intake URD MAF PnP Version (Very easy to install) Full Custom Exhaust 2.5" Stainless Steel Pipe, Doug Thorley Long Tube Ceramic Coated Headers, 2 stock catalytic converters (2 cat deletes), X Pipe, Dual Flowmaster Super 44s, 2 Jones 18 inch stainless steel tips, Full exhaust exits before rear passenger wheel like the SVT Lightning (I have Krisxone’s 09+ ECU adapter so I can go URD Boosted, Tested and working) 3 Inch Ultimate Toyotech lift (Silver Painted Coilovers) with Old Man Emu Leafs (No add-a-leaf here)
    I doubt they are different but I would call the dealer and ask. The only reason why URD has different years is because after 2009 Toyota switched the Tacoma to a 6 plug ECU while pre-09 have a 5 plug ECU which Gadget manufactured the URD S/C to work with and now is having a hell of a time getting the 6 plug to work.
  7. Jun 14, 2015 at 8:00 AM
    #67
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    URD doesn't make a SC for the 2014. TRD does.
  8. Jun 14, 2015 at 10:14 AM
    #68
    techbill
    techbill Active Member
    Bill
    2015 White Tacoma Pre-Runner
    TRD SuperCharger. TRD Cat back exhaust
    My take on TRD Supercharged Tacomas. I just traded my 2002 Pre-Runner that I bought new. The TRD S/C was installed a month after I bought it. The 7th injector kit was installed about two years later once they had introduced it and I was tired of the pinging.
    I drove that truck hard for 13 years. Had 131K miles on it. Never had any issues with the S/C or the truck until about a year ago, and even then it was minor annoyances.
    I did have to put new bearings in the S/C and replace the knock sensors.
    The S/C on the 3.4L just made the truck drivable, especially in the mountains of Northern California. The extra low and mid-range torque that works at altitude is wonderful. Instead of the transmission down shifting continuously and the engine buzzing near redline just to maintain 70mph, you just watch the boost gauge climb.
    I bought the new Tacoma today so i could get the TRD S/C on the 4.0L before they're all gone. Though the 4.0L shows simalar HP/Torque specs naturally aspirated as the 3.4L did S/C, the torque curve is all different. I still have to floor the accelerator in the 4.0L and buzz the engine to get up to speed. I can't wait to get the S/C installed.
    Being in California, and not wanting to work on a truck every day anymore, (I'd rather work on airplanes or motorcycles now) the TRD S/C is a great option. And as others had pointed out before, a better power to weight ratio, than getting a V8 Tundra or a Ford again.
    I drive pretty hard. No vehicle has held up as well as my '02 Tacoma did. I hope the '15 does as well.
    I constantly pushed the truck to 7lbs of boost, later to a little over 9 lbs when the 7th injector kit was installed. ( I think it cooled the incoming air which then expanded to give the larger boost) The I put on the URD undersized pulley and got a little over 10-11 lbs. With the greater boost, the top end was more, but it felt like I lost some mid range torque. TRD did a great job with their package. Don't get all excited by peak numbers for the sake of a great torque curve. I drive hard, but I don't drive with the engine spinning 5200RPM all the time.
    Sad to see TRD stopping their S/C program for the trucks. I can see stopping it for all the other cars. Originally they just had the Tacoma and I think the Supra. Then they got carried away with all the other engines. If they kept it for the Tacoma and Tundra, I think they could still make money with the program.
    My $0.25.
    Biscuits likes this.
  9. Jun 14, 2015 at 10:41 AM
    #69
    SYTFUxMBRProjects
    Mark
    San Leandro
    2005-2015 1GR-FE 4.0L Tacoma TRD Superchargers are all the same.
    Let me know when you (or anyone else) decide to get the TRD SC. I can get you a decent out-the-door quote for one installed.
  10. Jun 14, 2015 at 11:33 AM
    #70
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Toyota's stance on why they are nickin the TRD SC:
    "Increasing legacy costs associated with the recalibration of an expanding pool of past model year vehicles, along with rising development/engineering expenses and evolving emissions requirements have negatively impacted the program's return on investment to the point where it is no longer financially viable to offer these products for sale,"
  11. Jun 14, 2015 at 11:44 AM
    #71
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    With all the emissions crap they have to strap on, the 4 CATs newer Tacomas have for example, is gonna start negating the power the SC puts out. Toyota doesnt want to spend the money on the program cause they know in a couple years it won't be legal in all 50 states.
  12. Jun 14, 2015 at 6:35 PM
    #72
    Raincity
    Raincity Half man, half amazing.
    Lowermainland, B.C.
    '13 Mica Spruce DC.
    '12 DC TRD-RIP
    Are there any complete turbo kits available with manifolds, turbo, IC and tune? The quality of kits you can get for various other vehicles is quite high, I'm surprised URD hasn't jumped into that market. Maybe not enough interest but if guys are willing to shell out 5K for marginal gains.... And I'm not talking about the ones that mount remotely under the vehicle either.
  13. Jun 14, 2015 at 6:42 PM
    #73
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Nice,lol
    :quickdraw:
  14. Jun 14, 2015 at 7:10 PM
    #74
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Why does everyone post this stupid video. It was a Borg Warner Turbo that blew up, not Chinese. Chinese, Japanese, US, doesn't matter anyways; it was user error that cause it to fail.
  15. Jun 14, 2015 at 7:10 PM
    #75
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
  16. Jun 14, 2015 at 7:16 PM
    #76
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Don't buy the TRD Supercharger. Your engine will explode.
    https://www.youtube.com/watch?v=12x6iGWklzA
  17. Jun 14, 2015 at 8:01 PM
    #77
    Dubie220
    NorCal
    14 DCLB 4X4 Sport
    Thanks for all the info. Is it true a Toyota dealer has to install it in order to keep your standard and extended warranty? I asked the local toyota dealership service guy and he said no, I could install it and it would have no effect on the truck warranty. Not sure I want to go off one guys word though.
  18. Jun 14, 2015 at 8:12 PM
    #78
    Dubie220
    NorCal
    14 DCLB 4X4 Sport
    OK thanks, that makes sense
  19. Oct 2, 2015 at 11:40 AM
    #79
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    Its like Im psychic or something
