TRD value
Discussion in '3rd Gen. Tacomas (2016-2023)' started by buckshot67, Oct 13, 2022.
  1. Oct 13, 2022 at 4:43 PM
    #41
    islandhiker
    islandhiker Well-Known Member
    Calgary, AB
    2021 TRD Off Road AC
    I have a TRD Off Road, and honestly I think a V6 SR5 would suit most of us. I do like crawl control, and the locker has helped me once or twice, but I prolly shouldnt have been there in the first place! Just my thoughts, both are nice trucks though :)
  2. Oct 13, 2022 at 4:52 PM
    #42
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Unless the main objective is to hit up some rough trails, SR5 is just fine.
    Locker is needed in pretty rough scenarios, where most Tacoma drivers don’t go.
  3. Oct 13, 2022 at 4:52 PM
    #43
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Unless you are really piling on options, the MSRP is a little under 2 Grand difference between the SR5 and Sport/Off Road.
  4. Oct 13, 2022 at 4:56 PM
    #44
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    When I got my 2g I was dead set on an OR, but I ended up getting a regular cab. It felt more like a Toyota to me. I still wouldn't mind having the 4.0 and a rear locker in it, and the 6 speed manual.
    shakerhood and buckshot67[OP] like this.
  5. Oct 13, 2022 at 4:59 PM
    #45
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    People have brought up a lot of good points, one I did not see mention is lighting. If you like or want LEDs, any TRD is the way to go. If you’re good with halogen then SR5 is fine but they are tricky to upgrade to. That’s an expensive upgrade anyways but if it’s desired, the SR5 is kind of the wrong truck to start with. That’s just one aspect though and many don’t care about LEDs (though I do really like them on mine after having halogens first).
    buckshot67[OP] likes this.
  6. Oct 13, 2022 at 5:00 PM
    #46
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Wait, I have LEDs on my TRD Off-road?
  7. Oct 13, 2022 at 5:00 PM
    #47
    batacoma
    batacoma Truck Wars
    Access cab OR MSRP is a little over 40 Grand with LED headlights SR5 MSRP is around 37 Grand. It's the market adjustment that throws the whole thing off.
  8. Oct 13, 2022 at 5:01 PM
    #48
    buckshot67
    buckshot67 [OP] Member
    Do not have one yet.
    LEDs are on the verge of necessity with my aging eyes and not awesome night vision.
    MGMDesertTaco likes this.
  9. Oct 13, 2022 at 5:01 PM
    #49
    BLtheP
    Plano, TX
    Not sure what you’re asking. 2020+ TRDs could have LEDs and many did but plenty did not. SR5s did not and they are wired differently with the amber turn signal DRL so they are tricky bastards to upgrade later. The TRD is easy to upgrade with a simple wire harness if the truck came with halogens.
    MGMDesertTaco and buckshot67[OP] like this.
  10. Oct 13, 2022 at 5:02 PM
    #50
    BLtheP
    Plano, TX
    In that case I’d consider a TRD OR or Sport. There are plenty of them with the LEDs out there, although you may have to buy a few extras that come along with them in the package.
    when I got my OR I was bummed I didn’t get a sport because I thought it would better suit my needs. Honestly I’m glad I got an OR simply for the cushier suspension. It soaks up jolts better.
  11. Oct 13, 2022 at 5:03 PM
    #51
    Old goat1914
    Old goat1914 Well-Known Member
    Chicagoland, Indiana
    2016 TRD Sport DCLB 4x4
    It is easy to compare trims on Toyota's website. The TRD models have more features like blinkers in the mirrors. The SR trim can be optioned up similar capabilities. Knowing what I know after 6 years of ownership I would buy my TRD sport again. I still get "nice truck" compliments.
    Kllrbee and buckshot67[OP] like this.
  12. Oct 13, 2022 at 5:04 PM
    #52
    Integerdy
    Integerdy Aspiring "SR5 Pro"
    Eric
    So-Lame, Oregon
    21 SR5 Silver Sky DCSB
    This. Upgrading to LED Headlights on amn SR5 is expensive. But oh so worth it in the end
  13. Oct 13, 2022 at 5:05 PM
    #53
    BLtheP
    Plano, TX
    It’s expensive to upgrade a TRD also but at least it’s easy. The SR5 gets a bit weird and the results from the harness that Puppy punter, Dave and the other guys have worked to come up with seem to have iffy results. Sadly it can’t be a simple wiring change like the TRDs. But agreed the LEDs are definitely worth whatever it takes to get to them unless you need heat on the lens in the winter like bulbs provide.
  14. Oct 13, 2022 at 5:07 PM
    #54
    Integerdy
    Eric
    So-Lame, Oregon
    Morimotos were a 100% plug and play install. But if you want oem leds, you need a special harness made by literally one guy @Puppypunter
    Puppypunter likes this.
  15. Oct 13, 2022 at 5:08 PM
    #55
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Im happy with my SR5, it does great on the trails too. The stock tires are however, completely crap so you’ll want to change those out
  16. Oct 13, 2022 at 5:10 PM
    #56
    shakerhood
    Southern Ohio
    Yeah the market adjustment stuff is total BS.
    MSRP
    2022 AC V6 4x4
    SR5 $35,825 - OR $37,470
    2022 DCSB V6 4x4
    SR5 $36,705 - OR $38,405
  17. Oct 13, 2022 at 5:19 PM
    #57
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    I believe the rear end is a bit larger on the TRD OR and PRO as well. 8.75 vs 8 on the sport and SR/SR5. (basically if it has a locker it has an 8.75)
  18. Oct 13, 2022 at 5:20 PM
    #58
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    SR5 trim level and up come with the power adjustable drivers seat if that's important to you. It was to me so my shorter wife could drive it as well when looking at Tacoma's in 2020. It was a huge consideration. I would have been happy with a SR5 back then but the power drivers seat was only available on the TRD trims back in 2020.
    Also, I'm hoping this is my last truck before retirement so I threw caution to the wind and spent the extra on a DCLB TRD Sport trim. I regularly get compliments still after 2 years of ownership. I appreciate the sport suspension for highway driving and long road trips. Our cabin is 5.5 hrs away through 2 mountain passes. Mine is a daily driver as well. For my off road use it's awesome. Meets my needs of exploring Forest Service Roads, snow storms and extreme rain events. My second Toyota truck and the wife and I both love it.
  19. Oct 13, 2022 at 5:20 PM
    #59
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    Push to start and dual zone climate are now standard on V6 SR5s.
    CaptainBart45 and buckshot67[OP] like this.
  20. Oct 13, 2022 at 5:25 PM
    #60
    shakerhood
    Southern Ohio
    The Sport MT also gets the larger rear diff, as did the SR MT in 2016 and 2017 when it was available.
