Trd vs Ome 2.5in lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1998Yota4x4, Oct 22, 2015.
  1. Oct 22, 2015 at 10:44 PM
    1998Yota4x4
    1998Yota4x4 [OP] Member
    1998 toyota tacoma
    2.5 ome lift with 32x11.50x15
    I have a Toyota tacoma trd. I recently bought an Ome 2.5 suspension lift. The springs look the same exact size! Is the stock trd already lifted 2.5in? I feel like I might have just waisted 1300 bucks on an unnecessary upgrade?
  2. Oct 23, 2015 at 1:29 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    A trd sets the same height as any other 4wd or peerunner. If the springs you bought are actually the correct ones they will provide lift. Did u buy your truck new, u original owner? Could have already been lifted?
    Which ome springs did you buy??
  3. Oct 23, 2015 at 6:55 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Looks might be deceiving. The springs likely have a different spring RATE. Have you actually installed it yet?
  4. Oct 23, 2015 at 6:58 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    would be good get more details on the whole kit purchased
  5. Oct 23, 2015 at 8:25 AM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    Spring length is only one factor in ride height...
  6. Oct 23, 2015 at 8:55 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Stock TRD springs should look progressive rated style (towards the top maybe bottom can't remember the coils should be tighter coiled) vs OME that isn't progressive rated and more Linear the coils are the same if that makes sense.
  7. Oct 23, 2015 at 9:29 AM
    1998Yota4x4
    1998 toyota tacoma
    So I found out they sent me the 881 coils instead of the 882. So it only is a 1.75 lift. I'm ganna send them back and get the 3in lift coils. Thanks guys for the reply. The old shocks say toyota and are bilstien. With the 3 in lift will I need new cambers along with the uca to correct alignment?
  8. Oct 23, 2015 at 4:42 PM
    deckeda
    deckeda Well-Known Member
    '04 Double Cab PreRunner SR5
    "They?"
    I had no idea 882s would provide 3" lift.
