TRD VS. Standard alternator specs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by evan, Nov 8, 2008.
  1. Nov 8, 2008 at 3:35 PM
    evan
    evan [OP] Well-Known Member
    SK, Canada
    Can somebody point me towards some specs that show the actual difference between the standard alternator and the one that comes with the TRD package?
  2. Nov 8, 2008 at 4:42 PM
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
    There isn't a difference with TRD.
    There is a difference with the tow package.
  3. Nov 8, 2008 at 9:00 PM
    evan
    SK, Canada
    Thanks for the info guys. I'll see if I can verify the spec on the base alternator.
    I guess it's different across the border. In Canada we have three options: Base, SR5 power package, or TRD. The only one that comes with the upgraded alternator is the TRD package.
  4. Nov 9, 2008 at 6:03 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I read that the stock was 112 amp. cant remember where I found that, though. :confused:
    upon further searching, 80 amp IS listed as stock, no tow package. that kinda sucks. :-(
  5. Nov 9, 2008 at 9:27 AM
    evan
    SK, Canada
    Thanks Chris. What's your source?
  6. Nov 9, 2008 at 10:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I just did a general internet search. I found many sites that all gave the same 80 amp rating. I then called a couple of friends and they did the same. Problem though. I cant find out HOW the Toyota alt. is rated. If its at idle, 2000 rpm, peak, etc. Being as its only 80 amp, I can only assume its at idle, as most other alternators are rated much higher at 2000 rpm.
