trd wheels vs. stock
Discussion in 'Wheels & Tires' started by 09silvertaco, Aug 30, 2008.
  1. Aug 30, 2008 at 12:24 PM
    09silvertaco
    09silvertaco [OP] Well-Known Member
    Massachusetts
    2010 AC TRD Sport V6 6SPD
    do the 16 in baja trd wheels have the same backspace as the stock 16 in steel wheels?
  2. Sep 1, 2008 at 8:10 AM
    09silvertaco
    Massachusetts
  3. Sep 1, 2008 at 12:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    They should, but I cant find anything to verify this.
  4. Sep 1, 2008 at 2:48 PM
    09silvertaco
    Massachusetts
    thats what i was thinking as well. i guess my next question then is does anyone have 265/75/16 on stock steelies, stock height? i know thats the biggest you can go w/no lift, but i dont know if the alloys have a different backspacing allowing for the extra inch in width of the tire wo/rubbing.
  5. Sep 1, 2008 at 3:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You'll be fine. Many people are running that size with no issues. :)
  6. Sep 1, 2008 at 6:08 PM
    09silvertaco
    Massachusetts
    sounds good. thank you
  7. Sep 1, 2008 at 6:10 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    05prerunner is running the baja rims you should have no problem no issues.
  8. Sep 6, 2008 at 10:52 AM
    zero niner
    zero niner romeo oscar bravo
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    All Pro front plate bumper, 5100 1.75" Bilstein up front, 1" block and TSB in rear, UWS lowpro tool box, Toyota Side Steps
    So instead of starting another redundant thread, I'll just hop on here, so the 265/75R16 is the biggest I could go on the stock steel rim with a 1.75 lift in the front and a 1" block in back? Without any issues? Thanks in advance for confirming!
    Rob
  9. Sep 6, 2008 at 12:02 PM
    09silvertaco
    Massachusetts
    sounds about right rob.
  10. Sep 6, 2008 at 4:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That is correct. Though I would reconsider using a block to lift the rear. :)
  11. Sep 7, 2008 at 12:01 AM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    What would you suggest? An AAL? If so I'd be just lifting it even to stock and it will still have that rake, don't want to go to 3" in the front and have to do all the other stuff to make it right, plus I'm not planning on putting any thing bigger than 265/75R16 right now. Any input would be appreciated. Thanks.
    Rob
  12. Sep 7, 2008 at 12:15 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    rob....definitely go with an aal over a block man!!! the ride will be better(stiff at forst a little, but that will go away), and its safewr, plus you wont experience any axle wrap with the aal!!! just a heads up man!:)
  13. Sep 7, 2008 at 6:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yup! WHat he said! ^^^^^^^^^^^^^^^^
  14. Sep 10, 2008 at 10:59 PM
    sooner02r1
    sooner02r1 Well-Known Member
    Of course it will work. It's an OEM wheel with the stock size tire..... Why the need to wonder??
