Trdor dash rattle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RmikeD, Nov 17, 2017.
  1. Nov 17, 2017 at 5:21 PM
    RmikeD
    RmikeD [OP] Well-Known Member
    2016 Barcelona Red TRD OR DC V6 Auto, std bed, factory mud guards and bed mat
    Tow package, Factory Tonneau Cover
    My TRDOR has a slight dash rattle when hitting bumps. It is coming from the passenger speaker/defroster grill on top surface of dash right under windshield. If my passenger puts their hand on plastic grill it stops the noise. If I could remove it, an easy fix would be a small bead of silicone. Does anyone know how to remove this piece? Does it just pop out by prying under edge? Thanks in advance
  2. Nov 17, 2017 at 5:27 PM
    rsimi72
    rsimi72 Well-Known Member
    PNW
    2020 Tacoma SR5 Access Cab
    Simple to do, but you will need to remove the A-pillar first. Once the pillar trim is removed, the speaker grill pries up easily with trim tools. Be careful at the front of the speaker grill as those clips can break easily. Start there first when you pry the grill up, though. Just work carefully.
    Also, there is a very good chance that the rattle noise is coming from your speaker grill making contact with the A-pillar trim. A little felt tape in there might just solve your problem.
    Also, depending on what model you have, it could be the cap for the auto headlight sensor. I didn’t have the auto headlights so I just had a filler cap there instead. It tended to rattle. If you pull the speaker grill off, you can secure that from underneath.
  3. Nov 17, 2017 at 5:32 PM
    Roland79
    Roland79 Well-Known Member
    Dave
    Missouri
    2017 TRD Off Road DCLB Black
    I just noticed this in mine for the first time the other day, I just had my windshield replaced and I thought they did something maybe. I’m not 100% positive that’s where the noise is coming from on mine, because I can’t reach it when I’m driving and I haven’t had anyone ride with me yet, but I bet that’s what it is. It’s been driving me freaking batshit.
  4. Nov 17, 2017 at 5:34 PM
    rsimi72
    PNW
    If you are referring to the light sensor filler clip, you can easily wiggle it around and re-create the sound. It is pretty lightweight, but mine was making some noise. Easy to secure from beneath. A couple pieces of tape should do it.
    RmikeD[OP] and Roland79[QUOTED] like this.
  5. Nov 17, 2017 at 5:35 PM
    batong_23
    batong_23 vincedprince
    SoCal
    2017 white toyota tacoma trd sport
    ive been having that too in the morning when when im on my way to work. driving me crazy!!!
  6. Nov 17, 2017 at 5:38 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    This video will show you how to remove many panels in the truck for speakers. At around the 3:58 minute mark it starts on the A pillar and tweeter grill.
    https://youtu.be/c37zgaUQsVo
    rsimi72 and Roland79 like this.
  7. Nov 17, 2017 at 5:38 PM
    RmikeD
    2017SilverTRD, how do you remove the A-pillar trim? Never done that.
  8. Nov 17, 2017 at 5:44 PM
    Roland79
    Dave
    Missouri
    Where is the auto headlight sensor(or filler cap) located?
  9. Nov 17, 2017 at 5:45 PM
    20tacoma17
    2017 DCLB Sport AT
    See post #6
  10. Nov 17, 2017 at 6:00 PM
    rsimi72
    PNW
    You need to pop the two bolt covers first. Easy to do. Then remove the grab handle nuts and pull the cover off. The video posted above shows it well though it shows the driver’s side.
  11. Nov 17, 2017 at 6:04 PM
    rsimi72
    PNW
    The sensor or, in my case the filler plug, is actually located in the speaker grill cover. Passenger side. I bet the sensor, if so equipped, is secure. My plug was pretty loose. I pulled the cover and used a couple of small strips of gorilla tape to secure the plug from below.
    Roland79[QUOTED] likes this.
  12. Nov 17, 2017 at 6:06 PM
    Roland79
    Dave
    Missouri
    I don’t have the sensor, so I will check the plug. Whatever it is, It didn’t do it until after they installed a new windshield. (Or maybe I didn’t notice it, but I think I would of)
    rsimi72[QUOTED] likes this.
  13. Nov 17, 2017 at 6:14 PM
    rsimi72
    PNW
    As the temps drop plastics get louder. That plug is so light it might be more likely your A-pillar contacting your speaker cover. Super common issue. But if you are pulling the speaker cover to address your pillar rattle you might as well secure that plug, too. Or maybe they bumped the pillar cover and it’s now creating a tighter fit and rattling?? You might pull it to check it out and reset it. Less than 5 minute job.
