Tread Life Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GamerGuy, Dec 15, 2017.
  1. Dec 15, 2017 at 5:00 AM
    GamerGuy
    GamerGuy [OP] Well-Known Member
    Casey
    Alabama
    2025 4WD TRD Sport - Terra
    Does anyone know the Tread life of the Mickey Thompson 55752 Baja ATZ P3 Radial LT305/70R17.
    I have looked everywhere and can't seem to find anything. Is anyone else running ?
    I'm thinking ill get about 10-20k Left from my current Mickey Thompsons ( they have 20k on them already ). Is there anything better?
  2. Dec 15, 2017 at 5:20 AM
    GamerGuy
    Casey
    Alabama
  3. Dec 15, 2017 at 6:42 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    better for what?
  4. Dec 15, 2017 at 7:53 AM
    Pigpen
    Dan
    Northwest Montana
    Get a highway tire for tread life. If you want traction, you're going to be buying rubber regularly. I just dropped $1500 on rubber. I feel the pain, but it's all about smiles per gallon!
