Tread Wright 265/70/17 Guard Dog M/T
Discussion in 'Wheels & Tires' started by gsufan89, Apr 19, 2011.
  1. Apr 19, 2011 at 7:20 PM
    gsufan89
    gsufan89 [OP] Member
    I ordered my Bilstein 5100's and AAL. I will be setting them at 1.75 with a 1.5 AAL from Wheelers Off Road.
    My question is: Will these fit with no mud flaps? ( I know this size is widely documented to fit even on a stock setup but the following measurements have me wondering.)
    Because their site says that the Outer Diameter is 32.25" when Discount tire direct says that the Goodyear Duratracs are 31.7".
    I'm pretty new to all this so discount may be using a different way to measure their tires than treadwright.com, I just don't know because i am a noob.
    Any insight would be appreciated!
  2. Apr 20, 2011 at 1:18 PM
    gsufan89
    51 views and no answers, must be a dumb question. I'll assume they will fit.
  3. Apr 20, 2011 at 1:21 PM
    elgin
    elgin Well-Known Member
    Ian
    Southwest Colorado
    11 DC TRD OR 4x4
    i would assume so i ran 265 70 17 hankook dynapro atm with 17x8.5 wheels with no rubbing with the flaps off, just a little on the plastic on the fron wheelwell that i just push insideout with my hand
  4. Apr 20, 2011 at 1:23 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    they will fit. might have minor rubbing when at full-turn on mudflaps. no big deal.
  5. Apr 20, 2011 at 1:30 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    They will fit.
  6. Apr 20, 2011 at 1:47 PM
    bocna
    bocna Member
    nocal.
    2017 double cab.
    2017 OR SB. Stock 1999 prerunner off rd (sold), 2006 sport( Sold),magnaflow exhaust,bhlm,bilsteins 5100 front @ 1.75 and back. aal @1.50,17x8.5 atx thug,bfg ko 265 70 17
    I had the identical set you are talking about. 5100 f=1.75 and 1.5 AAL with 17x8.5 wheels but with bfg ko. And they did rub Both on the mud flaps and the plastic in the front. the rubbing happened only on full crank. Now with the front at 2.5 with flaps off there still a little rubbing on the front even after trimming of the plastic "only going up and down the drive way cranked"
