Treadwright.com - Looks like cheap BFG KOs
Discussion in 'Wheels & Tires' started by WaGood24, Nov 19, 2010.
  1. May 16, 2011 at 1:48 PM
    #121
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    its says to specify if you want all same cores.....
    did u do that:rolleyes:
  2. May 16, 2011 at 1:50 PM
    #122
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    when i talked to the wonam on the phone, yes. their website was screwy when i tried to order and wouldnt let me put in any shipping info.
  3. May 16, 2011 at 1:51 PM
    #123
    brutalguyracing
    F.U> GUYZ
    broken mods
    :cool:
    :cool:
    so what pressure you running in yours????
    have u done the chalk test yet.....
  4. May 16, 2011 at 2:00 PM
    #124
    The_Hodge
    SC
    they're mounted and balanced, but not on yet. these are just my trail tires. i'll mount them in the next day or two and run them before the drive on thursday to make sure they're good.
  5. May 16, 2011 at 2:43 PM
    #125
    thedude
    thedude Well-Known Member
    Lucas
    Little Rock, AR
    Interesting, I don't need the kedge grip, but if it made them ship two weeks faster it would be worth it.
  6. May 16, 2011 at 2:45 PM
    #126
    thedude
    Lucas
    Little Rock, AR
    "Kedge Grip provides additional traction in slippery conditions. It does this by creating small pits on the tread surface with the walnut shell and adding additional grit to the tread with the crushed glass. With the additional open area on the tread the tire will wear about 15-20% faster than a tire without Kedge Grip."
    No go for me, I don't need it and don't want my tire wearing out that much faster.
  7. May 16, 2011 at 4:57 PM
    #127
    brutalguyracing
    F.U> GUYZ
    broken mods
    mabye you want pep boys then same price
    then mabye a m/t tire is not for you.....
    what % of offroading do you do???? and what type mud / sand / rock
  8. May 16, 2011 at 5:00 PM
    #128
    tacopromatt
    tacopromatt Matt's Pro Taco (SOLD)
    Austin, TX
    2017 Cement Tacoma TRD Pro AT
  9. May 16, 2011 at 6:53 PM
    #129
    thedude
    Lucas
    Little Rock, AR
    No a m/t isn't for me, not much off roading, mostly highway. The Warden is an AT tire.
  10. May 16, 2011 at 7:02 PM
    #130
    thedude
    Lucas
    Little Rock, AR
  11. May 18, 2011 at 7:57 AM
    #131
    The_Hodge
    SC
    finally got mine slapped on the truck yesterday. the backbone's are fuggin loud.
    BGR, also just noticed that the A/T casing they sent me is a load range E while the m/t casings are a load range D. going to call them when i get back from harlan. also, 3 only needed 2-3ozs for balancing and one needed 12.5oz. per their note, that's beyond their specs.
  12. May 26, 2011 at 10:49 PM
    #132
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Just my 2 cents: I've just installed 3 sets of the Tread Wright gaurd dogs, load E, on 3 of my work trucks: (2) chev 2500 HDs, and (1) on F250. They've only been on for about 100 miles so far; so far so good, didn't require much weight to balance either. 2 sets are on BFG AT carcass, and 1 set is on Yokahoma Geolander carcass.
    First Impression: The Gaurd Dog has a tighter tread than other mudders, they make a "ZZZZZZ" instead of a "HMMMMM". They feel super smooth, smoother than my current Cooper STT and KM1s I've run in the past... but they are brand new, I'm sure the tone will change once they hit 50%. 1 set has been through about 100miles of rough gravel and no signs of chunking, the others have been on 95% road and look fine, again, brand new. The "retread" looks good, but is obvious up close on the sidewall where the new tread has been adhered to, but they still look fantastic considering the price: not bad, just noticeable if you're looking.
    The service/shipping has been excellent. There's only like 1 or 2 ladies that take the calls, already know me by name after 3 purchases. Price is right, paid like $480 to get all 4 to my doorstep + $40 for mt/balance.
    I'll update in 20K or so and let you know how they hold up: they'll be off-road alot, high highway miles, and all the time a loaded truck on top of them. If they hold up well through this (all other tires only last 1 year around us) I'll let y'all know either way.
  13. Jun 23, 2011 at 12:33 PM
    #133
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Bump. Really interested in these. Want more opinions.
  14. Jun 23, 2011 at 12:49 PM
    #134
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    very intersted in these as well. 400 bucks for some great looking 265/75/16 ATs!
  15. Jun 23, 2011 at 4:03 PM
    #135
    brutalguyracing
    F.U> GUYZ
    broken mods
    same here i put about 4k on them so far....mine have the kedge grip.....
    no complaints.........had 1 flat but it was a road debris that would have went into any tire......
    great in rain......
    im gonna try the other mt's next time...
    hell for under $600 for 4 285's i can try it:D
  16. Jun 23, 2011 at 4:05 PM
    #136
    brutalguyracing
    F.U> GUYZ
    broken mods
    just saw this....
    how did they work out a harlan???
    was the 12.5 oz weight on the load range e tire casting????
    if not mabye they have to rotate the tire on the rim......180*
  17. Jun 24, 2011 at 8:28 AM
    #137
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    Another update...
    The tread is still barely broken in. I've been to San Antonio again with zero problems. When it's time for a new set of tires, I'm getting these again.
    I did some light wheelin' with them, and their performance was great.
  18. Jun 24, 2011 at 8:30 AM
    #138
    tacopromatt
    Austin, TX
    I'm on my second set of Wardens (went down a size to 265 from 285).
    This second set was a littler harder to balance, as they took 5oz this time around. They ride great with absolutely no issues. I've taken plenty of road trips at 80mph with no problems. Highly recommended with great customer support.
  19. Jun 24, 2011 at 8:43 AM
    #139
    The_Hodge
    SC
    i wasnt able to do too much at harlan on them. the 12.5oz was on one od the D load tires. stuck that one and the e range on the rear. they handled fine on the road and did fine on the lil bit i got to do on the trails. they did appear to be slightly pulling apars at the tread/sidewall crease though on 1-2 of them
  20. Jun 24, 2011 at 10:16 AM
    #140
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Just got a guard dog D range 285 as a spare, haven't done anything with it - waiting on my rim to arrive.
