Tree Sap Nightmare..Seeking Help
Discussion in 'Detailing' started by TacoTurboMan, Jan 23, 2023.
  1. Jan 25, 2023 at 9:00 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Noooooo!
  2. Jan 25, 2023 at 9:34 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    rubbing compound???? doubt there would be much paint left when you're done
    Venom likes this.
  3. Jan 25, 2023 at 9:40 AM
    JTB Tacoma
    JTB Tacoma Well-Known Member
    Central NJ
    2015 Tacoma TRD, Super White
    Wonder if a rubber decal removal tool might be useful here? They're made to remove sticky stuff from cars without damaging the paint.
  4. Jan 25, 2023 at 9:50 AM
    Martian__
    Martian__ Well-Known Member
    Southern California
    That’s hard to even look at, I would say fill a container with rubbing alcohol and mineral spirt and have a clean microfiber soaked in it. Almost like you’re washing the area with it, just let it sit in the area for about 30 seconds and wipe.
    Also try a steamer to help loosen the sap.
    Last resort is some kind of acid wash from a detailer.
  5. Jan 25, 2023 at 10:26 AM
    WebberLander
    WebberLander Well-Known Member
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    If you have this tool or access to it, I would try a Dual Action Polishing machine with a hard/firm and coarse pad to do the elbrow grease work. These machines have built in clutches so you if you stay in one spot too long or apply too much pressure the pad stops turning which will prevent excessive heat build up. I would try the sap remover products mentioned applied to the pad(s) (you will need more than a couple) and see if it helps breakdown the sap. Keep in mind these pads are designed to remove defects and heavy contaminates from paint, so another type of pad will be required to help remove the marring/scratching the pad could cause.
    This is just a suggestion to help with the labor its going to take to remove. The heat gun method mentioned is also a good idea but obviously you want to be very very careful not to get one area too hot. That along with some plastic blades should help you to start taking off sections in big chunks.
    Good luck!
  6. Jan 25, 2023 at 10:37 AM
    Martian__
    Southern California
    Avoid doing the above until all tree sap is removed, otherwise you’ll be scratching the surface even more since all that sap with dirt will now be on the pad. This should be used at the end to remove all the micro scratches the rubbing has caused.
    You also want to be wiping in one direction to prevent swirl marks that look like spider webs in the sunlight.
  7. Jan 25, 2023 at 10:50 AM
    Danner488
    Danner488 Well-Known Member
    2016 TRD Sport
    Hand sanitizer works great cleaning pine sap off of my boat cover and I've used it to get sap off my windshield. I had tried the 70% IA and did not work as well. A nice thing about the sanitizer is it's viscous so you can goop it on and let it sit for a minute or so. It might be prudent to try an inconspicuous spot in case the sanitizer affects your paint, but it has never discolored the black fabric boat cover.
  8. Jan 25, 2023 at 11:01 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    The hand sanitizer may have less percentage of Isopropyl in it, but since it's a gel, it can stay on longer and remove it rather than quickly evaporate.
    You may want to unplug and remove the door and set it on some sawhorses to let the hand sanitizer sit on a parallel to the ground surface rather than just run off with gravity.
  9. Jan 25, 2023 at 11:08 AM
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    In my 30+ years as a self employed auto/aviation/marine detailer my go to for sap removal is Xylene. Its completely clearcoat safe and can be sprayed or wiped on and eats sap, tar and other contaminants with ease. It can be found at Home Depot, Lowes or any paint store.
    Another key factor in removing sap is getting to it before it hardens. It can still be removed but takes a lot more product and a lot more time.
    For your situation I would spray a partial area of the sap, let sit for approximately 30 seconds and remove with paper towels or rags you don't mind destroying with sap. Repeat until effected area is sap free and then apply your wax or sealant of choice.
    Pibbles99, Martian__ and Zillon like this.
  10. Jan 25, 2023 at 11:21 AM
    gorram
    gorram Well-Known Member
    2016 Limited
    Clay bar with lacquer thinner as lube?
    ace96 and Steves104x4 like this.
  11. Jan 25, 2023 at 11:45 AM
    Too Stroked
    Tom
    Disclaimer: He's being sarcastic. Do not try this at home - or anywhere else!
    photogr4x4 and Slick Taco like this.
  12. Jan 25, 2023 at 1:22 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    OP first step is ignore 99% of the recommendations in the post and take it to a pro. After seeing some of the recommendations, I hope some of you don’t procreate.
    2WD, ColoradoTJ, NMTrailRider and 2 others like this.
  13. Jan 25, 2023 at 1:54 PM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    Why?
    I read on Autogeek some members had good luck with rubbing compound.
  14. Jan 25, 2023 at 1:56 PM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    If it hasnt been said before, yellow bottle rain x. It is what every dealership I've worked at uses for quick sap removal.
  15. Jan 25, 2023 at 1:57 PM
    #35
    Venom
    Kevin
    Massachusetts
    I didn't say say "Rocks in a bottle compound" There's a lot mild compounds on the market. It doesn't have to be a correction compound. Could be a light, mild polishing compound.
    Dkurtz42 likes this.
  16. Jan 25, 2023 at 2:04 PM
    #36
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Yikes!! And it’s white too. With all the issues with white paint flaking after a few years, this may accelerate yours.
  17. Jan 25, 2023 at 2:48 PM
    #37
    Too Stroked
    Tom
    "Rubbing Compound" is very different from "Polishing Compound." Rubbing Compound was originally developed to polish out lacquer paint which needed lots of work to truly shine. And you started with that, then worked your way down the aggressiveness scale.
    In all my years in detailing, I've used Rubbing Compound once - about 30 years ago - with disastrous results. Wisdom comes from experience. Experience comes from screwing up. Never use Rubbing Compound.
    RustyGreen and Venom[QUOTED] like this.
  18. Jan 25, 2023 at 3:01 PM
    #38
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    blah blah blah ancient chinese secret is gas and a lighter
  19. Jan 26, 2023 at 4:31 AM
    #39
    Venom
    Kevin
    Massachusetts
    Terms are used loosely today.
    I read any Polishing Compounds are considered as a correction compound due to being abrasive. Most of my learning is from reading online. The dealership I detail at didn't teach me nothing. Just tell me to use this or that.
    When I was young I used Turtle Wax Bug and Tar remover on sap. It did a great job at removing all contaminants. It remove staining from white paint, minor imperfection. It was also abrasive. I can feel the abrasive rubbing it on the paint. Still they called a Bug and Tar remover.
  20. Feb 2, 2023 at 3:40 AM
    #40
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Heat it up with a heat gun, use a solvent on a micro rag and do small sections at a time. It's the best way to take it off. I'm a professional detailer for almost 40 years. You have to soften up the sap first.
    Taco 422 and EdableDonut like this.
