Tree Sap Nightmare..Seeking Help
Discussion in 'Detailing' started by TacoTurboMan, Jan 23, 2023.
  1. Feb 2, 2023 at 7:14 PM
    #41
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Update?!
  2. Feb 2, 2023 at 9:44 PM
    #42
    EdableDonut
    EdableDonut Well-Known Member
    Raymond
    09 white Tacoma,
    None. 220k miles, just did a major brake/ suspension overhaul to keep him on the road.
    @TacoTurboMan
    When I bought my truck it had year old dried tree sap. I found a video were the guy took a razor blade (listen to the screms) the long snap off type. He cut a total of 4- 1” long strip of painters tape and put two layers on each end of the razor blade. This raises the blade off the clear coat. But scrapes off a good 60-80% of the sap. Replace tape as it wears. Then use manual labor to remove.
    worked wonders for me, I used some tar remover, and lightly polished to a bright shine.
    Scroll down to see paint/ roof sap. [​IMG]
  3. Feb 2, 2023 at 9:49 PM
    #43
    EdableDonut
    Raymond
    09 white Tacoma,
    Thank you for this little piece of knowledge
    as a mediocre detailer 1yr :)
  4. Feb 3, 2023 at 12:13 AM
    #44
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    It's the best way, safest and less invasive. Don't use a razor blade!
  5. Feb 3, 2023 at 12:38 AM
    #45
    Dkurtz42
    Dkurtz42 Bill Hwang
    David
    Barberton, OH
    2023 Tacoma DCLB TRD SPORT 4x4
    - Gator ETX Soft Roll Up Tonneau - Clazzio black leather seats - Nitto Ridge Grappler 255 80 17 tires - Supreme Suspensions 2" and 1" lift
    I didn’t see Goo B Gone suggested once here…does that not exist out west? That stuff works wonders for a variety of sticky stuff.
  6. Feb 3, 2023 at 12:48 AM
    #46
    VaToy
    Parts Unknown
    Its kind of like paint over spray. Paint needs a light nibbing with some 2500 grit paper to knock the tip off and then a chemical used to wipe the un cured paint off. This sap needs to soften up, by heat then wiped off. It's not a hard process, cheaper than using a bunch of chemicals and causing a reaction to the paint which can soften up or stain. Heat it, wipe it away with a mild solvent is the fastest, less invasive and cheapest way!
  7. Feb 3, 2023 at 1:43 AM
    #47
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    As crazy as this sounds , I use peanut butter on my dogs fur to remove tree sap. Would PB be bad for the paint?. Not chunky though
    Slick Taco[QUOTED] likes this.
  8. Feb 3, 2023 at 12:36 PM
    #48
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    Yeah peanut butter is fine for your paint and could work for your sap issue as long as the sap has not hardened. The oils will break down the sap as it does on your dogs coat. Olive oil and coconut oil also work to break down sap as well.
    Pibbles99[QUOTED] and ColoradoTJ like this.
  9. Feb 3, 2023 at 12:48 PM
    #49
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Peanut butter. :rofl:
    I would have to lock up my kids and especially the dog.
    If this happened to this guy...local detail shop it would go.
    Pibbles99, Slick Taco and RustyGreen like this.
  10. Feb 12, 2023 at 9:26 AM
    #50
    DannyR
    DannyR Well-Known Member
    Daniel
    El Paso, TX
    2020 Quicksand TRD Off Road 4x4 DCSB
    Get 2 or 3 cans of 3M General Adhesive Remover spray and some cheap microfibers that you can throw away after, Costco has a 36 pack of yellow microfibers for around $20. Try it out, just keep it off of any textured black plastics and your TRD Off Road emblems on your front doors. Works great at removing anything sticky, like double sided tape, road tar and sap. Just let it sit for about 30 seconds then start wiping it off.
