@TRI-COLOR FOG LIGHT REPLACEMENT BULB (NEW PRODUCT)
Discussion in 'Lighting' started by CaliRaisedLed, Nov 4, 2019.
  1. Mar 2, 2020 at 8:36 PM
    #41
    Decepticon4991
    Decepticon4991 Just a dude
    NC
    Das Tacoma
    stock!
    Dang would've been sick to run those ambers, however your point makes sense. Thank you.
    huminajumina likes this.
  2. Mar 2, 2020 at 9:14 PM
    #42
    cubay
    cubay Active Member
    OC, CA
    Yea, I run the ambers more than the 6k color. Only thing that sucks is that every time I have to switch the fogs on and off to toggle from 6k to the amber.
    CaliRaisedLed[OP] likes this.
  3. Mar 2, 2020 at 11:10 PM
    #43
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Will they turn on in the headlight position, yes. Would any knowledgable person recommend it, definitely not.
  4. Mar 5, 2020 at 12:59 PM
    #44
    CaliRaisedLed
    CaliRaisedLed [OP] Well-Known Member Vendor
    Jake
    Texas (DFW)
    Exactly! :amen:
  5. May 1, 2020 at 11:24 PM
    #45
    Taco@NC
    Taco@NC Well-Known Member
    Mark
    Marion, NC
    2015 Blue Ribbon Tacoma Offroad 4x4
    Camper Shell, Door stil protectors, Color Matched Grille, Rugged Ridge floor liners, Redline hood struts, Anti-Dark hood light, and sPOD Universal 6 modular with an Iggy corp switch panel
    I grabbed a set of these tri color for a 12-15 tacoma! The bulb is loose in the fog light housing! Any thing i can do?
  6. May 8, 2020 at 12:36 PM
    #46
    CaliRaisedLed
    Jake
    Texas (DFW)
    Hello! Yes please feel free to reach us at info@caliraisedled.com and I tech can help you out.
  7. Jun 8, 2020 at 2:04 PM
    #47
    CaliRaisedLed
    Jake
    Texas (DFW)
  8. Jul 6, 2020 at 7:43 PM
    #48
    Bumble Jones
    Bumble Jones New Member
    2014 Tacoma TRD Offroad
    3" Toytec Ultimate, BFG KM2s, TRD Pro wheels
    Did you ever get this resolved? I have a 2014 and bulbs are loose in housing.
  9. Jul 8, 2020 at 2:57 PM
    #49
    TacoBlancoOffRoad
    TacoBlancoOffRoad Well-Known Member
    Derek
    Portland OR
    Blanco Taco TRD Off Road 18’
    I installed these this weekend. Bright lights, but not as advertised. The lights will not stay the same color if you turn your light switch to “off/on” it will change the color of the fog lights. I was under the impression that only turning the fog light specific switch would do this.
  10. Jul 22, 2020 at 12:57 PM
    #50
    dabbinuguay
    dabbinuguay Well-Known Member
    PDX, Oregon
    2017 Tacoma TRD OR DCSB
    So if you use your high beams, which turns off the fogs, does that cycle them when you go back to low beams?
  11. Jul 22, 2020 at 2:46 PM
    #51
    TacoBlancoOffRoad
    Derek
    Portland OR
    cant quote you on that exactly as I didn’t check. But I will say it’s frustrating Because they advertise it as set it and forget it- with the option of changing it as you please by turning it on/off. Now I have to cycle it EVERY TIME the lights go on.
  12. Jul 22, 2020 at 2:48 PM
    #52
    TacoBlancoOffRoad
    Derek
    Portland OR
    This isn’t true. Please update your advertising.
  13. Jul 22, 2020 at 11:19 PM
    #53
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    All these products work the same way. If it is shut off it will reset the cycle, it doesn't matter if that is because the truck was turned off, the fogs were turned off, the headlights were turned off also turning off the fogs, or the high beams were toggled on turning off the fogs. The product only has one 12v power wire, it doesn't know anything else.
    mainjet and CrazyAirborne like this.
  14. Aug 29, 2020 at 7:40 AM
    #54
    TacoTRDPR0
    TacoTRDPR0 New Member
    Francisco Cardenas
    2019 Tacoma TRD Pro
    Cali Raised LEDs
    Does the tri colored fog light from cali raised fit my 2019 Trd pro Rigid fog lights? Most of the videos and pictures i see online are only for the trucks that have the regular circular fog lights? I dont want to order and they wont fit ?Any info would be greatly appreciated. Thanks
  15. Aug 29, 2020 at 9:15 PM
    #55
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    No. The TRD Pro Rigid lights are fully sealed LED units, the light source is not swappable. They are also far higher performing than replacement LEDs in halogen housings.
    mainjet likes this.
  16. Sep 8, 2020 at 12:39 PM
    #56
    CaliRaisedLed
    Jake
    Texas (DFW)
    Thanks! That is correct.
  17. Oct 7, 2020 at 7:22 PM
    #57
    christian Not Daddy
    christian Not Daddy Well-Known Member
    Christian
    ILLINOIS
    2018 Off Road TRD 4X4
  18. Oct 27, 2020 at 4:23 PM
    #58
    CaliRaisedLed
    Jake
    Texas (DFW)
    Nothing at the moment! But stay tuned!
  19. Nov 5, 2020 at 10:00 PM
    #59
    boatshredder
    boatshredder New Member
    Ben
    2016 Tacoma Limited
    Wheel Spinners and a Vintage Popcorn Machine
    I hate to call out Cali Raised on here but this product has a major design flaw. When I'm driving the back roads and an oncoming car comes my way, I like to turn off the fogs (because they are awesomely bright) to be respectful. I then have to go on/off/on/off/on to go back to the color I was on. What a f'n bummer. It would be smart to have these lights go back to the original color after being on for a certain amount of time. That way you don't have to jiggle your wrist 5 times on a pitch black road to go back to your preferred color.
    Such a great product on paper but in practice its annoying. I'm going to gift these to a friend and get a different fog light set up because this is really annoying to have to do every time.
  20. Nov 6, 2020 at 3:21 AM
    #60
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Hint, hint ...
    https://www.tacomaworld.com/threads/the-led-sae-j583-fog-pod-fog-light-review.554813/
