"Tribal" Black LED Headlight Replacements. Thoughts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by binderline, Apr 25, 2017.
  1. Apr 25, 2017 at 6:01 AM
    binderline
    binderline [OP] Well-Known Member
    2019 TRD OR MT Cement
  2. Apr 25, 2017 at 6:08 AM
    Doughnut Spaghetti
    Doughnut Spaghetti Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
  3. Apr 25, 2017 at 8:28 AM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    I wouldn't put them on my truck, but I also don't see anything wrong with them.
    If you're going to install them yourself, make sure you find a thread or video with a guide. It'll save you a lot of time, headache, and broken clips.
  4. Apr 25, 2017 at 11:26 AM
    Hoyle
    Hoyle Well-Known Member
    Cookeville TN.
    2014 DCSB 4x4 Black
    A lot of stuff.
    I'm familiar with them. They also sold by "Spyder" https://www.carid.com/spyder/black-...-lbdrl-bk.html?singleid=83736413&url=79300532
    Your ref. on Ebay is cheaper.. I'm sure there the same.
    I tried them, removed and returned back.
    Why?
    1. Loss of DRL mode on light switch .. these lights only work in "parking" mode.. what I mean is those "cool" white bands only work in parking mode, DRL no longer does anything on your switch.
    2. Low beam and High beam are separate lights - high beam are not on the same time as low beams.. thus not giving me much output. I currently have HID's.. didn't want to reduce my lumens...
  5. Apr 25, 2017 at 4:27 PM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    It looks like they took an empty housing for a '12+ and put a bunch of random lights in it. The light layout doesn't make sense visually, and I guarantee you the light output is awful.
    If you want better light output and/or projectors, invest the time and/or money to do a proper retrofit.
    If you need to replace damaged OEM headlights and/or just want better light output, spend the extra money for a new set of OEM housings and do the "ultimate headlight upgrade".
  6. Apr 25, 2017 at 8:59 PM
    binderline
    Thanks all for the good info. Based on this input, I think I'll pass on these.
    Much appreciated!
  7. Apr 25, 2017 at 11:05 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Good call.
