Trick to repalcing headlight bulbs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BuddyS, Mar 1, 2021.
  1. Mar 1, 2021 at 2:38 PM
    BuddyS
    BuddyS [OP] Well-Known Member
    Maryland
    2013 TRD Sport 4x4 MT
    So I'm trying replace the bulbs with better incandescent bulbs from the auto parts store and it looks like there's no room in there to get the old ones out. Passenger side has about 1.5 inches between the bulb and the washer fluid bottle, and the drivers size is 2 inches from the battery. So is there a trick? Remove the actual light housings? Remove the bottle and battery? Find someone with really tiny hands?
    Thanks in advance.
  2. Mar 1, 2021 at 2:41 PM
    NBourque
    NBourque Well-Known Member
    Nick
    Maine
    ‘21 PRO
    I’ve never had a problem removing the bulbs but then again my hands aren’t all that big haha.
    Island Cruiser and BuddyS[OP] like this.
  3. Mar 1, 2021 at 2:42 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    No tricks. Just snug.
    Hardest part is wiggling off the electrical connector.
    After that, its all pretty obvious.
    Remember, force is an answer. Force may not be the right answer.
    6 gearT444E and BuddyS[OP] like this.
  4. Mar 1, 2021 at 2:43 PM
    dawgn86
    dawgn86 Well-Known Member
    2013 Toyota Tacoma
    I had to remove battery and washer bottle; don't see how it could be done otherwise
  5. Mar 1, 2021 at 2:43 PM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    "YouTube"is your friend.
    Marc70 and BuddyS[OP] like this.
  6. Mar 1, 2021 at 2:44 PM
    roadking1
    n.j.
    I did not remove anything to change headlight and foglight bulbs.
    vtown and BuddyS[OP] like this.
  7. Mar 1, 2021 at 3:14 PM
    BuddyS
    Maryland
    Ah, good advice. I see now that it is possible. I know I'm still going to curse a few times, and I'm going to have bloodied knuckles, but I know it can be done. Thanks!
    Island Cruiser likes this.
  8. Mar 1, 2021 at 3:26 PM
    busychild
    busychild Well-Known Member
    Alberta, Canada
    14 DCSB TRD
    TRD Exhaust, TRD Sport Short Shifter, Skid Plate, K&N Intake, Bakflip G2 Cover, Husky Liners, Falken Wildpeak ATW3. Alpine ILX-259, JL Stealthbox w 10TW3, JL XD600, 2x JL 650-x (front and rear doors), Subaru Kicker Tweeters, Motegi Traillite 17x8.5, Westin Side Steps .
    lots of cursing with assertive gentle force pulled it out. i probably should have waited for it to get warmer to do it it was in the winter made the rubber rather tough to get the rubber boot off. on one side the pin came out completely and had a pain the ass time trying to get that back on when reinstalling.
    i did unbolt the washer fluid assembly and move it out of the way gave me more room. i didnt need to on the drivers side.
    NAAC3TACO and BuddyS[OP] like this.
  9. Mar 1, 2021 at 3:28 PM
    BuddyS
    Maryland
    Yea, I was out there in 35 degree weather yesterday looking at it and I was like "No way this is going to happen until it's warmer or I can get the truck in a garage." :cheers:
  10. Mar 1, 2021 at 3:54 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    You think that causes bloody knuckles, wait til you decide to replace the parking light bulbs lol!
    BuddyS[QUOTED][OP] and 3JOH22A like this.
  11. Mar 1, 2021 at 4:05 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Did you pull back the fender liner and go at it from the bottom?
  12. Mar 1, 2021 at 4:18 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    For the passenger side, remove the bolts holding the windshield washer reservoir and turn it sideways. (Do not disconnect it.) This will give you just enough room to work. pull the harness connector off the bulb carefully by wiggling it a bit. Do not yank it off or you will cause bigger problems. Next carefully work the rubber boot off making sure not to yank the bulb out with it. Finally, carefully release the infuriating wire clip that holds the bulb in place. (You may want to take a picture of it before you do in case you drop it.) Swap bulbs making sure not to touch the glass with your skin. Now, reverse the process to put everything back together.
    For the driver side, you shouldn't have to remove anything although it is pretty tight in there.
    Good luck.
    pyrite4t3, SR-71A, 69L46Vert and 4 others like this.
  13. Mar 1, 2021 at 4:28 PM
    Island Cruiser
    Kauai
    Baja
    Nope from the top lol. I didn’t even know about going from underneath
  14. Mar 1, 2021 at 6:59 PM
    4x4cajun
    4x4cajun Well-Known Member
    Fredericksburg, VA
    2014 Limited 4x4
    CHEVERLY my service dog! Lol
    Yeah same here. I have big hands and had to move stuff to be able to see and move around.
  15. Mar 1, 2021 at 7:05 PM
    Clearwater Bill
    Billy
    Largo Florida
  16. Mar 1, 2021 at 8:23 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    you know what they say about guys with small hands......
  17. Mar 2, 2021 at 4:57 AM
    SJBlack
    SJBlack Well-Known Member
    I also had to loosen the washer fluid tank. My big mistake was not knowing there was a retainer clip on the bulb (LOL) that needed to be removed first.
  18. Mar 2, 2021 at 6:19 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Driver side, usually loosen the bracket on the battery to give me some room. Passenger side, remove the bolts from the washer fluid reservoir and plenty of room with my big hands...lol
  19. Mar 2, 2021 at 6:39 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Trying not to have any skin touch the bulb while wiggling your hand around just makes it that much more irritating. The longer life bulbs are worth the extra money in my opinion, especially if you do a lot of night driving.
  20. Mar 2, 2021 at 6:44 AM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    The connector and rubber boot come off easily. The problem is the wire clip. I stage the replacement bulb within easy reach. Then unhook wire clip and keep hold of it as you swing it out of the way. Remove old bulb, grab new one and install without touching the glass. Re-hook clip. If you let the clip flop around it may( and in my case did) fall out and may be lost. It isn't so obvious how it goes back in.
    Tacoma13_NC and jproffer like this.
