tricks to removing inside door panel?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ecampvet, Sep 19, 2012.
  1. Sep 19, 2012 at 10:53 AM
    ecampvet
    ecampvet [OP] Active Member
    with brushguard and ACE camper
    Any tricks to getting the plastic panel off? The wind caught the door and slammed it hard and now I have a rattle to fix inside the door. regular window crank, no side air bag.
  2. Sep 19, 2012 at 11:08 AM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    take out the screw behind the door latch and the one under the hangle and pull it off
  3. Sep 19, 2012 at 11:10 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    there will also be a U shaped clip that holds the crank on. they make a tool the helps remove it but I always used a flat head screwdriver on my old chevy.
  4. Sep 19, 2012 at 11:14 AM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    also the black triangle piece
  5. Sep 19, 2012 at 11:15 AM
    98tacoma27
    Ben
    Not Beech Creek
    The FSM also suggests using a rag. LOL
  6. Sep 19, 2012 at 11:37 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Pop off the black triangle piece by the mirror (and pull out the white clips that stay behind, be careful not to press these into the door. Install the white clips onto the black triangle piece you just removed before reinstalling. You can't just press the black triangle piece into the door with the clips installed in the door, the clips will just press into the door and your SOL), next, remove the 2 screws (one behind the handle, one behind the latch). Then, pull straight up on the front of the panel containing the electric lock and electric window buttons (the front lifts straight up, then slides forward to release). This allows you to unhook the wires so you don't have to wrestle with them later. Next, feel around the bottom of the door where the plastic meets the metal, toward the back you will feel a little indentation. Grad the plastic door cover and pull straight out starting at that point. Once all the plastic clips are freed, lift straight up to lift the window edge trim piece off the door and you're free. Sorry, sounds complicated but it only takes about a minute to have the inside door panel off :thumbsup:
  7. Sep 19, 2012 at 11:42 AM
    evh5150
    evh5150 Well-Known Member
    Eddie
    Auburn,Ma
    2010 D/C S/B V6 6 Speed
    Bilstein/5100 combo from Toytec. LR UCA's.1.5 AAL's Full audio upgrade.Pioneer 8400, JL Audio subs. All Boston Acoustic pro speakers, and a Kenwood XRS 5 amp. Grillcraft, Smittybuilt stainless steps. Debadged. Soon 17x8 ATX Ledge wheels w/285/70/17 BF Goodrich
    Hey I need to do the same thing and then try to figure out how to disconnect the factory without losing sound to the Boston Acoustics. Nice write up Pugga
