Tricks to temporary fixing torn CV boot
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KrnTaco08, Oct 11, 2020.
  1. Oct 11, 2020 at 5:17 PM
    KrnTaco08
    KrnTaco08 [OP] Well-Known Member
    LA
    2017 Taco
    my only worry was that the axle could “seize” due to the lack of grease and can cause some sort of failure.
  2. Oct 11, 2020 at 5:18 PM
    KrnTaco08
    LA
    2017 Taco
    Thank you for that. Gives me a little relief.
    eon_blue[QUOTED] likes this.
  3. Oct 11, 2020 at 5:22 PM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    The axle most likely won't seize unless you drive with the torn boot for a long time. People let those go frequently
  4. Oct 11, 2020 at 5:30 PM
    KrnTaco08
    LA
    2017 Taco
    Good to know. Thanks
  5. Oct 11, 2020 at 5:53 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    yes, you have time to do it however way you want.
    My personal experience with a split boot was in the '80s on a K-car.
    It didn't exactly keep the bottom clean but a little CV grease goes a long way, maybe it's made of Neverseize.
    KrnTaco08[OP] likes this.
  6. Oct 11, 2020 at 6:04 PM
    eon_blue
    Azusa, CA
    It can but there's still grease in there coating the bearings and internals. The main issue is that if the tear is big enough or you start going through water/mud, then debris can get into it and that will pose more of a threat. But a small tear/hole that lets the excess grease out won't cause any immediate danger to the axle imo. Biggest issue is that it makes an unholy mess
    Freegolf and BillsSR5 like this.
  7. Oct 11, 2020 at 6:35 PM
    KrnTaco08
    LA
    2017 Taco
    thanks for your input. Cleaning all that grease is what’s the most frustrating part about all this haha.
  8. Oct 11, 2020 at 6:36 PM
    slowtacotruck
    17 offroad
    stuff
    Wipe down what you can and then use brake clean on the rest.
    KrnTaco08[QUOTED][OP] likes this.
  9. Oct 11, 2020 at 6:41 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Lol. I tore a boot at 26k miles. Said fuck it. I'll run it till failure.
    Sold the truck at 300k miles. It never failed.
    Freegolf likes this.
  10. Oct 11, 2020 at 6:41 PM
    KrnTaco08
    LA
    2017 Taco
    brake clean? That’s good for cleaning grease? Thanks
  11. Oct 11, 2020 at 6:41 PM
    KrnTaco08
    LA
    2017 Taco
    damn. That’s crazy
  12. Oct 11, 2020 at 6:42 PM
    slowtacotruck
    17 offroad
    stuff
    Brake clean is good for cleaning almost anything and not leaving residue.
  13. Oct 11, 2020 at 6:42 PM
    koditten
    Kirk
    Central Michigan
    Well it only takes about 3 months then you forget about it.
  14. Oct 11, 2020 at 6:49 PM
    KrnTaco08
    LA
    2017 Taco
    That’s good to know. I Should buy a can for future clean ups or for obvious reason the brakes.
  15. Oct 11, 2020 at 6:50 PM
    #35
    KrnTaco08
    LA
    2017 Taco
    my OCD wouldn’t be able to handle that haha
  16. Oct 11, 2020 at 6:52 PM
    #36
    KrnTaco08
    LA
    2017 Taco
    i was using simple green to clean all the grease off.
  17. Oct 11, 2020 at 7:01 PM
    #37
    slowtacotruck
    17 offroad
    stuff
    That's no fun there! I'm definitely not going to encourage anyone else doing this but I found that spraying brake clean in the stream of air coming out of my blow gun works even better than just spraying brake clean alone lol.
  18. Oct 11, 2020 at 7:03 PM
    #38
    koditten
    Kirk
    Central Michigan
    Brake clean and starting fluid are very similar in their abilities to break down grease. Starting fluid is a dollar a can cheaper.
  19. Oct 11, 2020 at 7:04 PM
    #39
    slowtacotruck
    17 offroad
    stuff
    Does the starting fluid leave any residue?
  20. Oct 11, 2020 at 7:15 PM
    #40
    koditten
    Kirk
    Central Michigan
    None.
    I actually use it to "dry clean" my ball caps. It cleans the sweat stain off and dries residue free. You can wear the hat in 15 minutes.
    Works great on oil stains on the driveway concrete as well.
    I've never used anything better.
