Tried 2 different coil springs and lift height still too much
Discussion in 'Suspension' started by Drew12, Mar 29, 2017.
  1. Mar 29, 2017 at 9:26 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Well... thanks for the revelation. I hope you inform the rest of the world of your findings.
  2. Mar 29, 2017 at 9:28 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I've had that guy on ignore for months.
    10/10 would keep him there again.
    44357 likes this.
  3. Mar 29, 2017 at 9:33 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Sounds like your ignore button isn't working correctly.
    Justin- if a coil is sagging (or "settling") it is failing. I don't what revelation you speak of. It has always been this way.
    After you install and then lower the truck to the ground, drive it around the block once. The suspension will seat into its permanent position. It doesn't change 6 months later. Springs are not designed that way
    44357 likes this.
  4. Mar 29, 2017 at 9:36 PM
    Justinlhc
    So you're saying it "settles" after a drive around the block? But no longer than that?
  5. Mar 29, 2017 at 9:42 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    It's not the spring that settles, it's the bushings, spring setting into the perch under weight, etc. When the truck is off the ground the wheels are at full droop and kind of angled in. The drive around puts everything into its normal alignment. This might compress the springs a tad into their normal position.
    My point is the springs don't lose their stiffness over 6 months or whatever long time all the different myths and misconceptions state.
  6. Mar 29, 2017 at 9:42 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    wut
  7. Mar 29, 2017 at 9:44 PM
    Justinlhc
    Weird. Every spring or coil I've ever installed over the last ~20 years has given me the false impression that they do intend to settle over the course of a couple hundred miles. I think most people on here would say they experienced the same results.
    SnowroxKT and Speedytech7 like this.
  8. Mar 29, 2017 at 9:45 PM
    Justinlhc
    He said something about Earth being flat :notsure:
    Speedytech7 likes this.
  9. Mar 29, 2017 at 9:45 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    My past two sets of front coilovers would beg to differ with you, so would the rear coils on my mothers 4Runner, oh wait the springs on my old Ford Explorer would like a word as well. Strange to think that spring steel under constant pressure and occasionally shock load might weaken over time. Metallurgy is fun isn't it?
  10. Mar 29, 2017 at 9:51 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Mr. Eaton himself would like to have a word with you.
    Maybe you are confusing settling with compressing. Installed coils with an empty gas tank and then went and got it filled? Yeah, maybe we can call that settling in a round about way.
  11. Mar 29, 2017 at 10:00 PM
    OZ-T
    Peter North
    British Columbia
    What about when your front end is 1" lower than it was a couple years ago with the same weight
    Is that compression or settling
  12. Mar 29, 2017 at 10:01 PM
    Speedytech7
    I think you are attempting to use semantics to avoid being wrong. I know for a fact that my Ford Explorer (may it rest in peace) started out level (even held up under a full tank) and 13 years later sat with a heavy stern favored lean. Using your terms, it compressed permanently *cough* settled *cough*. Rhetoric and double speak are neato but kinda lose their luster when you study them...
    Anyway, I'm happy to say you're right, the world is flat, Churros are disgusting, the devil has never "went down to Georgia", and fat bottomed girls do not make the world go round. If that'll make you happy, cause I'm bored arguing the obvious, have enough of that dealing with daily politics.
    lynyrd3 and SnowroxKT like this.
  13. Mar 29, 2017 at 10:07 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Dude, after 13 years the coils are failing and need to be replaced. That is not what is being asked. We are talking new springs after install.
    I am wrong? I didn't know you are a spring engineer
  14. Mar 29, 2017 at 10:08 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Couple of years later? I dunno. Did you add a new bumper? Sliders, skids? Eat too many cheeseburgers? Bushings starting to wear? Other components out of alignment?
    Could be million different things
  15. Mar 29, 2017 at 10:12 PM
    #35
    OZ-T
    Peter North
    British Columbia
    I said same weight
  16. Mar 29, 2017 at 10:13 PM
    #36
    Speedytech7
    Hold up.... stop the presses.... disengage hyper drive... Springs fail?!
    Now we are speaking the same language, lets discuss time now. Is there a point where a spring just poof fails? Or does this happen over time, in this case a long time. Now, still with me, what if some of this long term lowering happens right at the beginning as you put load on it for the first time. Please tell me you see what I'm saying because I'm running out of creative ways to say it.
    SnowroxKT likes this.
  17. Mar 29, 2017 at 10:14 PM
    #37
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    There are many things that can cause it. Take it to the shop
  18. Mar 29, 2017 at 10:16 PM
    #38
    OZ-T
    Peter North
    British Columbia
    Nevermind
    44357 likes this.
  19. Mar 29, 2017 at 10:18 PM
    #39
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Are you trying to tell me that a spring fails within a day of install?
    If you are asking me if a spring sags after 6 months, depends on the miles and amount of abuse inside that time, but for most people in normal driving conditions no it does not. 10 years? Yeah probably a little.
    It is becoming obvious you don't know what this conversation is about because you are arguing a fact that has nothing to do with what the adults are talking about.
  20. Mar 29, 2017 at 10:23 PM
    #40
    Speedytech7
    @T4RFTMFW I tried, I really did. That whole ignore thing looks pretty decent right now
    I suppose you only hear what you want to hear in the end. Either way I tried, perhaps one day a light will come on and it will all make sense
    T4RFTMFW likes this.
