Tried SEAFOAM in the Crankcase...?????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mr.Tacoma, Jan 16, 2011.
  1. Jan 16, 2011 at 6:54 PM
    Mr.Tacoma
    Mr.Tacoma [OP] Well-Known Member
    toronto
    DoubleCab4x4
    TRD Exhaust, Side step bar & ARE cap
    Has anyone tried SEAFOAM rinse in the crankcase before the oil change to clean out the deposits, sticky valves..??
    I have done it in my CAMRY planning to do it in Taco next time while oilchange.
  2. Jan 16, 2011 at 7:12 PM
    Mr.Tacoma
    toronto
    DoubleCab4x4
  3. Jan 16, 2011 at 9:49 PM
    Taco11
    Taco11 Well-Known Member
    Seattle WA
    You probably had nasty gunky rings and the seafoam cleared it up causing them to leak.
    Mr.Tacoma why do you want to do this? Have you been changing your oil like you should? Using good gas? What are you hoping to accomplish by using Seafoam?
  4. Jan 16, 2011 at 9:50 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Never have and never will.
  5. Jan 16, 2011 at 9:56 PM
    747 function > form
    1st Gen.
    I've only used it in the gas tank..."feels" (read: subjective) peppier afterwards.
  6. Jan 17, 2011 at 12:32 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    use it all the time on old junk. Shouldn't be seeing it in a 2005+ yet.. but I suppose its possible. My old 1984 celica seemed to have unending sludge back in the mid 90s.
  7. Jan 17, 2011 at 12:44 AM
    Celtic
    Celtic Tactical Trunk Monkey
    Nick
    McKinleyville, CA
    2015 Black Tacoma AC TRD 6MT V6
    Only stuff I have ever used to put in the tank to help with sticking valves is BG products 44K. We would have cars with CEL (check engine light) and multiple misfires caused by sticking valves, after a can of that, they never had a problem afterward, (also running the recommended octane from good stations helps it not come back) But I am an ASE certified tech, so I wouldn't BS you guys.
    I have seen something else be used for the Crankcase for the inside of engines, but not sure I should go into that here.
  8. Jan 17, 2011 at 1:18 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    Not for anything but what is it with the seafoam. If your changing your oil regular and using your truck on a weekly basis (another words its not sitting around for a year without being started) why the f*&k would you even bother with that shit. Just a fad that alot of people fall into. And if your truck has made it to extreemely high milage 150k+ why screw with it.
  9. Jan 17, 2011 at 2:53 AM
    reg boulette
    reg boulette Well-Known Member
    Can't find Seafoam? Make your own: (according to the WHMIS sheet)
    -naptha (from your camp stove)
    -kerosene (from the camping heater)
    -isopropyl alchohol (better quality gas line antifreeze or 99% from Walmart etc.)
    Start with a ratio of 1/3 for each ingredient and adjust as necessary.
  10. Jan 17, 2011 at 5:07 AM
    Mr.Tacoma
    toronto
    DoubleCab4x4
    I Know it does great deal of a job, i hav used it on 2 diff motorcycles..1985 &1986 Yamaha Maxim X..it turned the sluggish rpms to very responsive tacometers..also gear shift has been dramatically improved. My tacoma is 2006 & has 117..my theory is as long as we dont drive around (just idle for 5 or 10min without load)it shouldnt do any harm!! Here is a PDF that explains...
  11. Jan 17, 2011 at 5:18 AM
    98tacoma27
    Ben
    Not Beech Creek
    You will still develop a carbon build up in the intake at regular oil change intervals. And you will still develop some sludge on a regular interval oil change.
  12. Jan 17, 2011 at 6:09 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    I use synthetic oil only in all my vehicles and once a month I put a litre of lucas gas treatment in my tank. Also I use only sunoco 93 octane which has cleaners in it. None of my vehicles have ever had any significant buildups of carbon or sludge that would effect performance or longevity.
  13. Jan 17, 2011 at 6:14 AM
    98tacoma27
    Ben
    Not Beech Creek
    So you've torn them done to prove this?
  14. Jan 17, 2011 at 6:36 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    never don't kick a sleeping dog!
  15. Jan 17, 2011 at 6:44 AM
    psmcn
    psmcn Well-Known Member
    Paul
    Rockville Md
    Carbon build up on the top end is going to happen. There is always the old Italian Tune up to help with that. Red line 'er at least once a week!.... A good fuel additive every once in a while will help this as well as not using cheap or old fuel.
    Sludge on the other hand can be prevented with regular Dino oil changes. I had an old VW w/300K+ miles, in town mostly, and regular dino oil changes. I pulled the pan to replace the oil pump at 250K and no sludge just a nice golden color. If you keep it clean it will stay clean. Under the valve cover looked just as nice.
    My understanding is that Syn oil will not sludge like the Dino. It can be run at higher temps with out viscosity breakdown. I run Syn in all my vehicles and have never had a sludge problem.
    Every engine I've pulled apart ,that I maintained, was as clean as could be inside. Motorcycle engines are especially hard on oil because of the shearing effect of the transmission, the particle from the wet clutch and blow-by that get into the oil. I have never had sludge in them as well.
    Most oil additives that you pour in may help. Some people use kerosene other us ATF others us that Murphy's Mystery oil stuff or as here SeaFoam. Most oils already have the cleaning additives in them already. Just take normal care of it and it will be fine. save your money for other upgrades.
    Just my opinions and techniques, that have worked for me for the past 30+ years.
    paul
  16. Jan 17, 2011 at 10:29 AM
    island808
    Jedediah
    hawaii
    lot of wives tales in this thread.
  17. Jan 17, 2011 at 12:03 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    key words in my initial reply. (no SIGNIFICANT deposits to effect performance ). If you run premium fuel (which has cleaners in it) and use syntho oil at proper intervals along with a fuel additive like lucas these will be minimal. Too minimal to even be concerned with,. Dont have to tear them down one of my vehicles has over 300k and my son is still using it. runs fine and doesnt burn any oil. Replaced the oil pan gasket and there was no significant sludge to speak of.
  18. Jan 17, 2011 at 12:05 PM
    98tacoma27
    Ben
    Not Beech Creek
    Well said.
  19. Jan 18, 2011 at 11:26 PM
    bwilson624
    bwilson624 Well-Known Member
    Brandon
    Marion, NC
    07 TRD OR
    Fog light mod, bed lights, led dome and maps, ABS/VSC mod, turn signal mod, led lights in console and glove box, Sockmonkey Trd decal, blacked out badges, tinted tails
    Ah. The old maxims. Bout forgot about those
