tried to change oil today but...
Discussion in 'Technical Chat' started by fireturk41, Jun 7, 2009.
  1. Jun 7, 2009 at 5:14 PM
    fireturk41
    fireturk41 [OP] I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    it seemed like the drain plug was torqued on there! i usually ratchet it an ounce above hand tight but i tried to take it off and it felt like i was gonna rip out the oil pan before the drain bolt. do they sometime torque on because of pressure? ive never had this happen and should i break out the torque wrench tomorrow?
    also anyone know any good exhaust shops near greenville nc, my check engine light came on and the obd reader narrowed it down to the exhaust/fuel system
  2. Jun 7, 2009 at 5:15 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    I used a breaker bar on my first one...
  3. Jun 7, 2009 at 5:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Tap the wrench with a hammer, and see if that helps. The plug should only be about 30 lb-ft.
  4. Jun 7, 2009 at 5:47 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    oil plug should come off fairly easily. also....for the cel.....try tightening the fuel cap a few clicks and reset the light...see if thats the problem.
  5. Jun 7, 2009 at 6:09 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    did give it a shot to no avail
  6. Jun 7, 2009 at 6:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Post the code that was given.
  7. Jun 7, 2009 at 6:16 PM
    98tacoma27
    Ben
    Not Beech Creek
    x2
  8. Jun 7, 2009 at 6:18 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
  9. Jun 7, 2009 at 6:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Check for exhaust leaks at the manifold, pipes, catalytic converter. Repair as required.
    Use a scope to diagnose the oxygen sensor operation (Tip: The oxygen sensor in front of the catalytic converter normally has a fluctuating waveform. The waveform of the sensor behind the converter should be more steady).
    Inspect the downstream heated oxygen sensor (HO2), replace if necessary
    Replace the catalytic converter
  10. Jul 19, 2009 at 7:07 PM
    mpgnc64
    mpgnc64 Well-Known Member
    Mike and Denise
    Western NC
    06 4x4 Access cab 4cyl 5spd, 2000 Prerunner
    Tool box, Thule rack, rod holders, 5100s at 1.75 and the TSB
    Bob's Muffler in Goldsboro does great work.
  11. Dec 11, 2009 at 7:01 PM
    themaine1
    themaine1 Member
    South Carolina
    00 TOY
    alarm, speaker upgrades
    What was the outcome?? I am having what sounds like the same problem...Noise from under the truck, but chasing down a "EGR Vaccuum Problem" with no good results. I have a cracked manifold and am trying to find a "good" fix for that which may fix my PO420...Sounds like a plan to me! BTW 2000 Taco regular cab with 319K miles!!!!
  12. Dec 11, 2009 at 7:03 PM
    98tacoma27
    Ben
    Not Beech Creek
    Your cracked manifold may be the cause of your egr issue.
  13. Dec 11, 2009 at 7:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2.
