trim discoloration, who has it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dapetik, Aug 6, 2014.
  1. Aug 6, 2014 at 11:27 AM
    dapetik
    dapetik [OP] Well-Known Member
    David
    Barboursville, Va
    2015 TRD Sport
    Magic bedcover, sweet ass floormats, rocket boosters, warp drive
    My trim around the windows looks almost moldy. I've tried armour all, wd40, and various other products. I can't tell if it is stained or what. Anyone else have this?
  2. Aug 6, 2014 at 12:45 PM
    Aces and 8s
    Aces and 8s Sean266's Lover
    I have found that a Mr. Clean magic eraser works well on trim and molding. A bit of water and some elbow grease and you're good to go.
  3. Aug 6, 2014 at 12:50 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    looks like mold to me :notsure:
    my 08' has it everywhere.
    Toyota quality is going downhill... my buddys 85' rubber looks better and so does his paint. It's disgraceful and Toyota should stop counting beans so much...
  4. Aug 6, 2014 at 1:47 PM
    braik
    braik Well-Known Member
    Louisville, KY
    2006 4.0L 4x4 BASE
    2" Ironman 4x4 (B) Front Spacer Level LR UCAs Level 8: Tracker Wheels 255/75 Cooper ATPs Welded Rock Sliders Weathertech floormats Wet Okole seat covers JVC Head Unit Diff Breather Mod Zip Tie Mod Needle Bearing Mod HID Retrofit (Acura TL-R)
    WD-40 eats rubber. The mold looking stuff looks to me like the smooth outer layer had worn off in splotches. The Magic Eraser is a mechanical abrasive, that's why it cleans so well. It takes a small layer off the top, like sandpaper.
    I'd say the WD-40 made it worse.
  5. Aug 6, 2014 at 5:26 PM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    Back To Black or a similar product will make the black plastic like new.
  6. Aug 6, 2014 at 9:00 PM
    Richie Rich
    Richie Rich Toyota Hoarder
    760 (San Diego)
    2010 X-Runner 2011 TRD Sport DC 4x4
    More than I can afford
    Mine has it on just about everything made of rubber. Yuk.
    And ditto on the older ones. Other then the black coating wearing off from being rubbed/windblown for 27 years and 275,000 miles, all the trim on my 87 looks better then my 2010.
  7. Aug 6, 2014 at 9:44 PM
    Pool Runner
    Pool Runner Well-Known Member
    Nor Cal
    '14,TRD/OR, Entune & Nav '13 Subaru Outback
    Lowes Slimline Tool box, OEM Bug shield.
    You know, my three month old 2014 Tacoma's trim looks a little like this already. I think the automatic car washes have something in the spray, that has really poor pH. The first time I noticed it, was about 15 min after a touchless wash. I didn't hand dry it, and it was a really hot day.
  8. Aug 6, 2014 at 10:02 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  9. Aug 6, 2014 at 10:19 PM
    Badgerr
    Badgerr Member
    Johnathan
    North Carolina
    99 Single Cab Prerunner
    Magnaflow Hi-Flow Cat Glasspack Muffler
    You could just buy new ones...They are around $40 bucks a pop
  10. Aug 6, 2014 at 10:43 PM
    smith945
    smith945 Member
    South East Massachusetts
    2012 Off Road Dbl. cab
    OME at the corners Dakars at the back, Total Chaos UCA's, Leer cap, Pelfreybilt battery cage
    Try some 303 protectant next time.
