Trim Under Headlight 2003 Toyota Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by ericinga, Apr 14, 2019.
  1. Apr 14, 2019 at 12:36 PM
    ericinga
    ericinga [OP] Active Member
    Eric
    2003 Toyota Tacoma
    When I bought this truck it was missing the trim piece under the driver side headlight. I finally ordered the piece and had it painted and put it in. After about a year, I noticed one day it was gone again. I have bought another one and need to know is there a trick to installing them? I have seen other 1st Gen Tacomas missing both trim pieces and it just drives me crazy that it is missing but don't want to keep buying the piece if its going to keep falling out.
    six5crèéd, GQ7227 and CS_AR like this.
  2. Apr 14, 2019 at 1:24 PM
    joea99
    joea99 Well-Known Member
    2002 3.4 TRD 4WD auto
    They do seem to fit a bit insecurely. Mine have not fallen out yet. I guess what I might do is put a tab of silicone on the end and tab and slip it in.
    six5crèéd and ericinga[OP] like this.
  3. Apr 14, 2019 at 1:33 PM
    Dan 77
    Dan 77 I leave my bikes outside
    Dan
    San Antonio
    06 DCSB TRD Sport 4X4
    Kings and TC UCAS 01 DCSB 4X4 Totaled All-Pro bumper, mile marker winch
  4. Apr 14, 2019 at 8:22 PM
    Beater_Bimmer
    Beater_Bimmer Well-Known Member
    San Francisco, CA
    2002 Tacoma 4x4 DCSB
    When installing, just make sure you bend the tabs a bit to fit more securely. A dab of 3M adhesive might help keep them there...
  5. Apr 15, 2019 at 1:38 AM
    1997tacomav6
    Denver
    If I remember correctly There are actually plastic locking tabs that hold the filler panel in place to the grill. These plastic tabs fail over time from age.
    Just get new OEM locking tabs from the dealer and they will not fall off and get
    OEM filler panels for a better fit. I think OEM are 20.00 each. I just bought new ones last week OEM.
  6. Apr 15, 2019 at 5:42 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I took mine off this weekend to remove the fender and found the plastic locking tabs. Good to know these can be ordered locally.
  7. Apr 15, 2019 at 5:47 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I run a bead of clear caulking across the top of mine and smooth it in with my finger so it is recessed back into the groove. You cant see it unless you are really looking for it.
    six5crèéd and GQ7227 like this.
  8. Apr 15, 2019 at 8:27 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    zip ties!
    This is literally how my whole grill is held on.
    six5crèéd, CS_AR and GQ7227 like this.
  9. Apr 15, 2019 at 8:37 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    those don't come pre-painted do they?
    had to get mine redone recently and paint it black ... lotta rock chips and touch-up paint over the years
    six5crèéd likes this.
  10. Apr 15, 2019 at 8:42 AM
    jbrandt
    Justin
    If you have some color matched duplicolor spray paint, it's really easy for something so small. I'm even considering painting my grill black just so I don't have to match the color, lol...
    six5crèéd and GQ7227[QUOTED] like this.
  11. Apr 15, 2019 at 10:43 AM
    1997tacomav6
    Denver
    Yes, like he said you can get a can of spray paint that will match your truck color and then put
    clear bra film over the paint to deal with the rock chips on the filler panels
    six5crèéd, CS_AR and GQ7227[QUOTED] like this.
  12. Apr 15, 2019 at 11:14 AM
    TacomanTurd
    TacomanTurd Well-Known Member
    David
    2004 Tacoma
    Stock for now
    Yep, my 04 is missing the driver side too. I’ll put some adhesive on it when I install it. Thank you fo the trick
    six5crèéd and CS_AR like this.
  13. Apr 17, 2019 at 7:31 PM
    ericinga
    Eric
    2003 Toyota Tacoma
    I purchased mine twice from Ebay and I do have the matching spray paint I use to paint them and it looks great but for them to fly off and me not even know, that is a waste of time and money. I tried to find the clips but so far no luck.
  14. Apr 18, 2019 at 10:51 AM
    CrawfishTaco
    CrawfishTaco Alright, alright, alright
    Zack
    West Central Texas
    2002 4x4 2.7L 5spd SR5 Xtra cab
    Same, my dude. zip ties, duct tape, and baling wire keep my truck from falling apart. Haha
    ericinga[OP], six5crèéd and CS_AR like this.
  15. Apr 18, 2019 at 5:23 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    If your grille is OE and those are aftermarket, that could be the issue. I had a ordered a grille off Amazon as well as eBay. My OE filler pieces did not like the aftermarket grille at all. Didn't want to snap in correctly.
    If you want a perfect fit without all the hassle, drop the coin for OE.
  16. Dec 23, 2019 at 5:36 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    I found a piece that looked like it came off an old appliance laying in our driveway last week and threw it away. A week later I notice it’s this piece of trim under my driver headlight. Oops.
  17. Dec 23, 2019 at 7:03 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    sounds like something my brother-in-law would do while intoxicated & working on his vehicles
  18. Dec 23, 2019 at 7:36 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I been sober for 8 years and had no idea what it was or how it got there, lol.
    GQ7227[QUOTED] likes this.
  19. Jun 24, 2021 at 4:41 PM
    ericinga
    Eric
    2003 Toyota Tacoma
    When the first replacement came off I didn't know it for a few weeks and remembered riding down the road and something hit my side mirror and it sounded huge. Wasn't sure what it was but later noticed the piece was gone and tried to remember where I was when the thing hit my side mirror but of course never could remember. I was told if I take the whole front off and ziptie or put a pin in it, it should stay but have to take it all apart.
  20. Jun 25, 2021 at 6:16 AM
    crackedmirror
    crackedmirror Well-Known Member
    do these provide any structural support or protection? or are they purely for looks? thinking about removing mine
