Trimmed Mud Flaps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FL4x4Taco, May 30, 2009.
  1. May 30, 2009 at 12:40 PM
    FL4x4Taco
    FL4x4Taco [OP] Well-Known Member
    Trimed the front and rear flaps this morning. Turned out great!! I trimed the front ones 2". That wasn't enough, so one more inch. Still not enough. Decided to give it 9" of clearance from the ground. Gave the rear flaps 10" of clearance from the ground. Check the pics. Even the wife says it looks better now.
    2" from bottom of tape to bottom of mud flap. First cut.
    Series of cuts:
    Finished Front Flap:
    Trimed a bit off the rear flaps, I'd say approx 3/4" to get the 10" from ground to flap.
    Overall shot:
    I'm 110% happy with this mod. Note, I did NOT remove the flaps from the truck. End result is the rear flaps are 1" higher than the front flaps; 9" front clearance, 10" rear clearance. I used 2 different grits of sand paper to work the edges and make it look like nothing ever happened. Sand paper did a great job cleaning up the edges. FYI, I did not use those red sheers for gardening. I used a pair of Swiss/wiss metal snips like what you use for commercial metal framing. And yes I used a Level and 2 vise grip clamps to make sure the cut line was perfect. I went around and measured everything, I'm within 1/16", not to shabby of tolerances.
  2. May 30, 2009 at 12:46 PM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    looks sweet man. what did you use to cut the flaps with
  3. May 30, 2009 at 12:48 PM
    Dellosa89
    Brian
    Murrieta CA
    oh never mind i didn't read ur thread all the way.
  4. May 30, 2009 at 12:48 PM
    hoosiertaco
    hoosiertaco Well-Known Member
    Looks real good. Nice job!! I want to do my fronts.
    What was total amount you cut off the front. 2+1+?.
    What kind of cutter did you use?
    Edit: nevermind, you edited on us...LOL Great pics too!!
  5. May 30, 2009 at 12:51 PM
    FL4x4Taco
    Tool of cutting: Wiss Metal snips. You get these at Home Depot, for about $30. They are used by commercial metal framers; metal studs. That's why I have a set. They cut this stuff like butter while giving good control of the cut... and I had them in my tool box which was very convenient! Cost for this: $0. Time: 1.5hr for all 4.
    Not sure what I cut off the front total. 2"+1" + IIRC 5/8". It now measures 9" from flap to ground on my stock TRD. What I can do is measure how long the flaps themselves are. so if you have a lifted or mod'd truck you can measure from the truck.
  6. May 30, 2009 at 12:54 PM
    hoosiertaco
    btw, great finish on that garage floor too!!!:D
  7. May 30, 2009 at 12:56 PM
    FL4x4Taco
    LOL. I'm not used to fancy garage floors. I'm used to grease, oil etc. and having to de-grease it every 6 months with a deck brush and garden hose. but this house came with the floor finish done.
  8. May 30, 2009 at 1:00 PM
    hoosiertaco
    well it looks good, and also, welcome to the 'World'. Rep to you for contributing with great pics right out of the gate!!:thumbsup:
  9. May 30, 2009 at 1:02 PM
    Dellosa89
    Brian
    Murrieta CA
    hey would u mind measuring the flaps them selves cause i have a lift and bigger tires.
  10. May 30, 2009 at 1:17 PM
    FL4x4Taco
    Front- 7-1/2". Rear- 8-1/2". However the rear flaps are still 1" higher off the ground. This is being measured from the low point of the fender flare.
  11. May 30, 2009 at 7:49 PM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Yea, I am going to trim my front flaps soon too. They look too long anyway, and are brittle as hell.
  12. May 30, 2009 at 7:53 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    That looks so much better than stock. Nice job bro.
