Trimming and Wheel Offset Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Be3fTaco, Nov 11, 2012.
  1. Nov 11, 2012 at 9:40 PM
    Be3fTaco
    Be3fTaco [OP] Member
    Here's the deal. I just ordered a 2013 Double Cab, and I want to put on a 3" lift, tires, and wheels. After doing some research, I've decided on an OME lift kit. I am also planning on running 285/70R17 BFG T/A KOs on Black Rhino Sidewinder 17x9 wheels.
    I've got two main questions:
    1) What kind of "trimming" would be required for such a set-up, and what does the "trimming" entail? Would there be cutting and welding I would need to do? Would there be holes in the wheel wells from the trimming? Pictures would be helpful.
    2) Should I get the wheels with a -12 or +12 offset? Would either one reduce the trimming I would need to do? Are there advantages or disadvantages to either?
    Thanks for sharing your knowledge!
  2. Nov 12, 2012 at 2:40 AM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    welcome to tw sir
    trimming is the easiest part of doing your lift. all you have to do is remove the front mudflaps and cut off the lower part of the plastic in the front of the front wheel wells.
    if you plan on offroading tho, youll need to do the cab mount chop, which is the cuting and welding part. I skipped that tho and im fine on-road.
    I dont know about offsets.
  3. Nov 12, 2012 at 2:43 AM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    Of those 2 options you'll need to get the +12 offset. Trimming is not bad and is easy as mention by Tru.
  4. Nov 12, 2012 at 9:25 PM
    Be3fTaco
    Thanks for the advise and the warm welcome to the forum. Do you guys know if I will need to run any spacers on my wheels?
