Trimming Emblem Tape
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoLarry, Apr 22, 2020.
  1. Apr 22, 2020 at 7:34 AM
    TacoLarry
    TacoLarry [OP] Well-Known Member
    Larry
    PacNW
    14 Tacoma DCLB Myca Pyrite 4WD
    Having successfully installed the new tailgate I am now contemplating tranferring the emblems from old to new. They removed just fine with a heatgun and putty knife and I have them cleaned up, but am a bit concerned about properly trimming the 3M 411 tape.
    I see that the original adhesive was die cut to match the letters and 1" wide tape is 'flexy' enough I am not sure that attemting to use an Exacto knife around the letters will be cosmetically effective.
    What methods have you with experience successfully used?
  2. Apr 22, 2020 at 7:48 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Attempting to trim the tape to look professional will be problematic. Most body shops just purchase and install new emblems.
  3. Apr 22, 2020 at 8:38 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Good luck with that. I tried and failed miserably, as that tape just stretches and smears using an xacto knife. I just ended up buying new emblems.
  4. Apr 22, 2020 at 11:08 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    What I've done, not for this, but the same type of issue... Apply the tape to the emblem then from the tape side, cut at a slight angle following the emblem. Use a sharp blade and cut on the push.. don't try cutting when pulling back.
