Trimming fender wells
Discussion in 'Wheels & Tires' started by utmck, Jul 22, 2011.
  1. Jul 22, 2011 at 9:34 AM
    utmck
    utmck [OP] Active Member
    What tool(s) did you use to trim your fender wells to prevent tire rub?
  2. Jul 22, 2011 at 9:40 AM
    05tacoSPORT
    05tacoSPORT Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    4" grinder and cut off wheels. Measure twice. Mark with grease pen. Tape off. And cut slowly. If you go too fast you will burn the paint. And remember= once its gone IT'S GONE. Then once cut use grinding wheel and make the cut look nice. TAKE YOUR TIME
  3. Jul 22, 2011 at 9:41 AM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    And post pics
  4. Jul 22, 2011 at 1:43 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    What tire size and lift?
  5. Jul 22, 2011 at 1:46 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
  6. Jul 22, 2011 at 2:07 PM
    utmck
    No, no, no, I'm sorry I meant the inner fender well.
  7. Jul 22, 2011 at 2:12 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    The plastic? I just used a sharp utility knife to cut mine. Fresh razor blade cuts the plastic like butta.
  8. Jul 22, 2011 at 2:37 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    i just used some tin snips....razor knife would work too.
  9. Jul 22, 2011 at 2:38 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I just used my little dremel. Worked like a charm.
  10. Feb 27, 2014 at 12:31 PM
    badnum21
    badnum21 Member
    texas
    2005 sr5
    the plastic inner fender wells... do you need them? mine are rubbing and falling down can I remove them and not worry about water/dirt/mud getting up there? thanks
  11. Nov 22, 2015 at 7:05 PM
    JeffP213
    JeffP213 I used to do mods. I still do, but I used to, too
    Jeff
    Central, VA
    15 TRD OR
    Hey man. Did you ever get an answer on this? What did you do? I know the passenger side plastic is covering up the intake, but I'm just rubbing on the driver's side. Not sure if ripping that stuff out will mess anything up...
  12. Nov 23, 2015 at 8:34 AM
    2nd screen name
    2nd screen name Tacodelaplaya
    Bob
    LV/SD
    06 AC Sport Prerunner
    Front: Maxtrac, DK heim UCA, 6112 Rear: AP expos, Fox 2.5 RR DSC Fn fivestar with General reds
    It's fine don't worry unless you live somewhere salty.
  13. Nov 23, 2015 at 8:38 AM
    Large
    Large Red
    I drove without both of mine in for a long time and had no issues. I would, however, remove the plastic nose of the air intake under the passenger side fender well if you get a lot of rain / muddy conditions. It could potentially suck water in your intake.
