Trimming Pics
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Notty, Jan 28, 2009.
  1. Jan 28, 2009 at 12:26 PM
    Notty
    Notty [OP] Well-Known Member
    5Twenty
    2017 DCSB TRD OR
    Bilstein 5100s OME887 Deaver AAL BAMF CMC ECGS Bearing Replacement Sprint Booster
    I have searched and not found much for pics of the trimming required to fit 285/70/17's with a 3 inch lift. Can somebody please post pics of exactly what you had to trim? Preferably a close up and and a not-so close up so I can really get an idea of where to trim! My new wheels/tires are getting mounted up tomorrow and I wanted to get the trimming out of the way before I went to the shop! Thanks!
  2. Jan 28, 2009 at 12:36 PM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    MY opinion is to wait until you bring it home. Take your time coming home then when in the area check for yourself (not being a smart A^*) Mark the area then trim.
  3. Jan 28, 2009 at 12:37 PM
    longbow
    Bill
    Indiana
    Here is the flare area I had to trim, the other area has to much snow now so no pic.
    I am running 285's on 16's
  4. Jan 28, 2009 at 12:41 PM
    Notty
    5Twenty
    2017 DCSB TRD OR
    Yeah, I considered doing this too. I was just concerned that I would rip the fender off or something! haha I guess I am just unsure of how much it's really going to rub. Is it just enough to make noise and be annoying, or enough to do damage?
  5. Jan 28, 2009 at 12:43 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    You probably won't run into real issues until you flex the suspension so the drive home should be fine. Just stay on the road. ;)
  6. Jan 28, 2009 at 12:44 PM
    longbow
    Bill
    Indiana
    X2 and also don't make turns so sharp.
  7. Jan 28, 2009 at 12:45 PM
    Notty
    5Twenty
    2017 DCSB TRD OR
    It's approx 30 miles from the shop to the house!! :eek: haha I'll take it easy then and take care of it afterwards! Thanks for the input!
  8. Jan 28, 2009 at 12:46 PM
    longbow
    Bill
    Indiana
    Good luck and............post some pic's when done. :)
