Trip computer terrible?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mark77, Dec 27, 2021.
  1. Dec 27, 2021 at 10:49 AM
    Mark77
    Mark77 [OP] Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    My truck told me i had 9 miles to go, low fuel light was on. My scan gauge said i had 48 miles to go. I filled it up, and it only took 18 gallons. So, obviously something is off, and its not my scan gauge. Unless Toyota gave me a 18.7 gallon fuel tank.
    Im averaging 16 ish mpg city driving dueing the week.
    Anyone elae get suck different nunbers?
    I know its not good to drive it so low, fule pumps are usually cooled by the fuel. But thia was just way off. I wanted to keep driving and see what happened.
    Sdswingr and Spankomatik like this.
  2. Dec 27, 2021 at 11:00 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Pick one indicator. Use it. You will develop a "feel" for it in a bit of time.
    So, out of curiosity...... How many gallons do you want to consume on a fill???
    Jester243 and philth like this.
  3. Dec 27, 2021 at 11:05 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    There is nothing wrong and perfectly normal. The fuel light comes on early and leaves a reserve of a gallon or two. Search here for low fuel light and you will see.
  4. Dec 27, 2021 at 11:17 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    This is the best gauge to go by:
    Everything else is just an estimate.
    Jester243, 02Duck and philth like this.
  5. Dec 27, 2021 at 11:20 AM
    Knute
    You have loads of fuel left. No need to be concerned until the little red pointer falls below the hash mark near the E.
    I typically will pick up 19-20 gallons on a fill.
    Mark77[OP] likes this.
  6. Dec 27, 2021 at 11:21 AM
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
    I am rarely if ever below a quarter tank.
    Jester243, Junkhead, jt13077 and 4 others like this.
  7. Dec 27, 2021 at 11:22 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    It is a 21 gallon tank but there is a 3 gallon reserve. Meaning it will read “empty” with roughly 3 gallons still in the tank. This is a safety mechanism that Toyota uses so people don’t run the fuel pumps dry which would lead to premature failure
  8. Dec 27, 2021 at 11:52 AM
    Hafaday
    Hafaday Well-Known Member
    Bill
    Richmond, VA.
    19, DCSB, Off Road. 23 KLX300, 14JKU
    Take this for what it’s worth..
    Mine at new, the low fuel light would come on quickly with several gallons and miles left. I would run it lower every time the light came on, and the info would change. Granted I did this for shits and giggles. But now, the light comes on with a lot less in the tank and fewer miles to go. I think learns a little from the driver and also as to what kinda driving you are doing, highway vs. city.
  9. Dec 27, 2021 at 12:00 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    My average fill-up with about 65k on the Taco is almost 18.75gal. So quite often, I am putting 20gal+ in there. The low fuel light coming on at 18gal used and DTE going 0mi at 19gal used has never waivered. Many folks in many threads have verified this behavior.
    DTE at full is a BS number and can vary. Same with the match between the shown MPGs per tank at fillup and the hand calculated ones.
    Of course, there are some odd variables between individual Tacos. I'm not discounting your experience, but just noting what I have seen on mine and what a large group of other folks have found.
  10. Dec 27, 2021 at 12:04 PM
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    I don’t even know if my fuel light works, I never go below 1/4 tank
  11. Dec 27, 2021 at 12:09 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Every late model vehicle built and sold in the United States after 2015 has the fuel light set to come on with 3-5 gallons left. This was put in place by a request from brother to auto manufacturers, since my sister in law runs every vehicle down to the light on every tank, and leaves the next day with his vehicle that always has a half or tank more. Sorry for any inconveniences, but after running out of gas about every other month, their lives are much better now.
  12. Dec 27, 2021 at 12:14 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Your "miles to empty" is merely an estimate. As many have said, you'll have several gallons in reserve upon getting there. Best not to push it, especially for the sake of your fuel pump. You'll also notice that the "miles to empty" rating falls faster below 1/4 tank. It's best to fill around 1/4 of a tank anyway just so you have plenty of reserve and, if you're like me and live in a winter climate, you'll have extra weight over the rear end.
    philth and Red Alert like this.
  13. Dec 27, 2021 at 12:22 PM
    Hafaday
    Bill
    Richmond, VA.
    Understand that.. Just saying that when it was new and the first time I had the low fuel light. I put in 16 gallons. I remember this as I thought it was a very conservative number. After that, and running it lower and lower several times. my personal fill up has changed to when the light comes on.
    Now, I can really care less to a point about fuel economy, it’s a truck. But my noticing that the fill up is more gallons with the low light changing to lesser miles.
    my $.02
    I do not usually run it low. But have to see actual fill up from empty.
    tonered[QUOTED] likes this.
  14. Dec 27, 2021 at 12:33 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is weirdly high. It might have been learning?
    I don't worry about MPGs as much as Range. For whatever reason, I like to get 400mi per tank.
    :cheers:
    Hafaday[QUOTED] likes this.
  15. Dec 27, 2021 at 12:38 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    OP's truck warned him that it was starting to get low on fuel and the truck was not wrong. Seems to be working as designed, albeit the truck and the truck owner apparently have different interpretations on what low means. .
    philth, Chew and HighCountryTacoma like this.
  16. Dec 27, 2021 at 12:47 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    the dash computer is an AIDE.............
    no one has touted it to be 100% accurate
    no less it averages the info against the recent driving environs
    i just came off a trip hiway legal speeds NO cruise
    440+ miles to a tankful
    actual miles driven / 19.4 gals used
  17. Dec 27, 2021 at 1:41 PM
    Mark77
    Mark
    Nothing yet
    This.
    Good info fellas. Im coming from a 2006 xterra that had a light that would go on when i had like 1 to 2 gallons left, depending. 3 gallons still in the tank is alot in my opinion.
  18. Dec 27, 2021 at 2:27 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I would not trust scan gauge, especially with a chronic issue with fuel pump..
    Btw, 2017's trip/mpg computer is dead on.
  19. Dec 27, 2021 at 3:25 PM
    jt13077
    jt13077 Well-Known Member
    CNY
    2021 Black DCSB TRD OR
    same
    Junkhead likes this.
  20. Dec 31, 2021 at 6:48 AM
    Hafaday
    Bill
    Richmond, VA.
    :notsure: 4 hunnndred? :annoyed: The best mine has ever said was 330. Guess I need to really start doing the actual math if I really cared. :D
