Trip meter reset randomly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sandman614, Oct 10, 2013.
  1. Oct 10, 2013 at 11:32 AM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Has anyone else seen this? My trucks Trip B has reset randomly. This also has happened on my gfs Honda Accord, same scenario. What's the limit on the Trip meters?
    Both times I was resetting Trip A at a gas station after filling up. We use Trip A to keep track of my gas mileage and Trip B to keep track of Oil Mileage (I use synthetic). After resetting Trip A I cycle back to the Odometer, but when it went to trip B on my truck it said 1.7 miles when it should have read nearly 10,000 miles. I hadn't even left the gas station parking lot and Trip A still was 0.
    Neither vehicle has charging or dead battery issues. I replaced the battery in my truck several months back.
  2. Oct 10, 2013 at 1:31 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    They do roll over but I can't remember at what mileage they roll over at.
  3. Oct 10, 2013 at 1:47 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    I would hope it's more than 10,000miles
  4. Oct 10, 2013 at 2:26 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    I don't think so. It's less than that. If it goes into the thousands than it definitely won't go any higher than 9,999. You most definitely just found the max, it didn't randomly reset.
  5. Oct 10, 2013 at 8:14 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    All of these trip meters are defective! :)
  6. Oct 10, 2013 at 8:36 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    it resets at 10,000 i believe...
  7. Oct 10, 2013 at 8:40 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    I guess you don't go for the little stickers on the window, or a receipt in the glove box...
    Now that you mention it, I found out why I can never verify if I'm getting more than 10,000 miles on a tank of gas...blasted trip meter keeps resetting!
    Pigpen likes this.
  8. Oct 11, 2013 at 12:22 PM
    jbrenn
    jbrenn Well-Known Member
    allen texas
    10 sr5
    I know for a fact 09 crv trip only goes to 9,999 miles. i would think that other hondas are the same. I have never done more than 1000 miles on my trip.
  9. Oct 11, 2013 at 12:25 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Looks like 9,999 miles is the cut off then.. LAME
    No I change my own oil. I already have enough reciepts in my glovebox/armrest. Gas reciepts get the mileage when I fill up and then when I get sick of the mess I put them in Gas Buddy.
  10. Oct 11, 2013 at 12:29 PM
    bjboucher
    Brad
    San Antonio, Texas
    My '09 Mazdaspeed3's trip only went to 999.9. Not even 1,000. Count yourself lucky I guess if you're complaining about 9,999.
  11. Oct 11, 2013 at 12:30 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Survey says: 9,999 and back to 0. Mystery solved.
  12. Oct 11, 2013 at 1:47 PM
    bjboucher
    Brad
    San Antonio, Texas
    Even with synthetic I don't think I'd go over 10K miles without changing it. That's putting a lot of trust in your oil.
  13. Oct 11, 2013 at 1:56 PM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    If you're replacing every 5k it's easy. 35k 40k 45k 50k. Whenever the odometer says a 5 or 10k multiple is when it gets changed, period. Because I know the last change was at or very near the previous 5 or 10k mark. If you're currently on say 36k, just go 4k and start my simple 5k plan. I don't think I've looked at my B trip since about the third oil change.
  14. Oct 11, 2013 at 2:02 PM
    bjboucher
    Brad
    San Antonio, Texas
    I guess the early 2nd gens don't have the oil change dummy light that turns on every 5,000 miles?
  15. Oct 11, 2013 at 2:03 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Do you have fat fingers? Or too much caffeine?
    I've reset both of mine accidentally before. it's not difficult to do.
  16. Oct 11, 2013 at 5:38 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    +1 ... When I first started using synthetic I had the idea of going to 10K, got to around 7.5K and didn't like the color of the oil on the dipstick. Changed it and went with the every 5K plan. That was a different vehicle 12 years ago. ... no I do not want to have the "that means the oil is doing it's job debate." :rolleyes:
    This. :thumbsup:
    They do. It's outta synch with my schedule...and it just now dawned on me to reset it (the maint required light) next oil change. :cookiemonster: DUH ... frickin' sometimers strikes again. :eek: :D
  17. Oct 11, 2013 at 6:10 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    My '08 has one, but the light doesn't start flashing until 4500, comes on at 5000.
    I use Trip-B so I know when I should be checking my stock of oil and filters. Also, if I were planning a cross-country trip, I'd change the oil before leaving if I were over 2500.
  18. Oct 11, 2013 at 6:25 PM
    bjboucher
    Brad
    San Antonio, Texas
    That makes total sense to me, but I still don't understand why the OP needs it to go more than 9,999 miles.
  19. Oct 11, 2013 at 6:46 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Maybe he's tracking tire or brake life?
  20. Oct 11, 2013 at 6:49 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Don't give them any ideas.
