Trip meter reset randomly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sandman614, Oct 10, 2013.
  1. Oct 11, 2013 at 7:01 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Flames?
    No... that was Goodyear
    Firestone fucked up something else and never got a chance to fuck up the Tracer.
    And Firestone rubber is great. I've got the Destinations on my 5 lug... I've put over 45k on the truck and the tires are not showing wear... and I don't know how many miles were on them when I bought it. Truck had 53k. I doubt they are the stock tires, but I dunno....
  2. Dec 7, 2016 at 8:47 AM
    Jpoisso
    Jpoisso Member
    Jimmy
    2007 White Tacoma w/access cab 2.7
    None
    Back to the original question...Tripmeters both reset at start-up on my 2007 Tacoma. New Battery...Any suggestions other than getting a new instrument panel???
  3. Dec 7, 2016 at 8:51 AM
    98tacoma27
    Ben
    Not Beech Creek
    They were at 0 after the battery change or keep going to 0 every time you start the truck?
  4. Dec 7, 2016 at 8:57 AM
    Jpoisso
    Jpoisso Member
    Jimmy
    None
    Yes. Before and after battery change. Was working for a while I know then it didn't... thanks
  5. Dec 7, 2016 at 8:59 AM
    Jpoisso
    Jpoisso Member
    Jimmy
    None
    Resets to zero every time now.
  6. Dec 7, 2016 at 9:55 AM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    You might have a bad ground somewhere. Does your clock reset when the ODO does? Check the body ground off of the battery.
  7. Dec 7, 2016 at 10:07 AM
    Jpoisso
    Jpoisso Member
    Jimmy
    None
    The clock does not reset...just the mileage A and B...
    The battery terminals were retightened just this past weekend...as I was installing the Cruise Control handle on the steering wheel. Before and after was the same though...The resetting started after I had dash off running wires for new 12v power outlet, Satellite Radio, and/or for Wiring for Door Lock. Maybe the Instrument panel has a short??? Thanks
  8. Dec 7, 2016 at 10:12 AM
    98tacoma27
    Ben
    Not Beech Creek
    Sounds like you need to revisit the wiring. You may have tapped into something you shouldn't have.
    Sandman614[OP] likes this.
  9. Dec 7, 2016 at 10:43 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    The body ground, where the battery negative is bolted to the body..
  10. Dec 7, 2016 at 10:48 AM
    Caltech90
    Caltech90 Well-Known Member
    '19 TRD OR T4R
    Just installed cruise on mine and I noticed the trip reset after I reconnected the battery. Didn't think anything of it. Is there a coin battery behind the cluster that stores the trip data? I wouldn't think so but, hey you never know I'm new to tacomas.
  11. Dec 7, 2016 at 10:53 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    No memory system. It's supposed to reset when you disconnect battery.
    Caltech90[QUOTED] likes this.
  12. Dec 7, 2016 at 1:28 PM
    Jpoisso
    Jpoisso Member
    Jimmy
    None
    Thanks for the suggestion about Body Ground...I will definitely check that.
    As for tapping into something when wiring the add-ons...I went to the Battery thru the firewall direct for the 12volt outlet fused at the Battery...
    Also I used the Add-a-fuse for the Power Door Lock. But I could have as it is an older 2007 with lots of dust under the dash!!!!
    Thanks...More fun to come.
