Trouble adjusting SAW 2.0 coilovers
Discussion in 'Suspension' started by kumaWRX, Dec 19, 2009.
  1. Dec 19, 2009 at 11:00 PM
    kumaWRX
    kumaWRX [OP] Well-Known Member
    Jase
    Oahu, Hawaii
    2004 TRD Offroad PreRunner 3.4L V6
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    Is it just me or are these coilovers ridiculously difficult to crank up? So I tried to crank them up before I installed them which didn't work because the spring and top mount kept spinning. So I installed them in the truck but now the UCA is in the way so I couldn't get the spanner wrench in there. Then I jacked up the LCA to simulate the suspension being loaded, now I can adjust them but because the weight is on the spring they are crazy hard to turn the adjusting collar! So I only cranked them so that about 1.25'' of thread is showing on top and I was just too exhausted to crank them up any more than that. Any help is appreciated.
  2. Dec 19, 2009 at 11:00 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    try using a cheater bar and something to lube the threads up
  3. Dec 19, 2009 at 11:27 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    you have to jack the truck up so the wheels are off the ground. and did you loosen the set screw on the collar. my 2.5's were a pita as well.
  4. Dec 20, 2009 at 12:57 AM
    kumaWRX
    Jase
    Oahu, Hawaii
    I did that but the UCA was drooped down and in the way so I had no other choice than to jack it up by the LCA which loads the spring. And yes I did loosen the set screw.
  5. Dec 20, 2009 at 11:58 AM
    bajamoon
    STEVE
    Whittier
    the best way i found was to leave the truck alone, don't jack anything and lube the threads then turn as hard as you can.
  6. Dec 20, 2009 at 2:29 PM
    kumaWRX
    Jase
    Oahu, Hawaii
    But if I just have the truck as is, not jacked up or anything, I can't even get the spanner in there because the UCA is in the way.
  7. Dec 20, 2009 at 4:58 PM
    bajamoon
    STEVE
    Whittier
    can you take a pic of the uca at stock height, i had enough room like said above. about a 1/4 turn at a time.
