Trouble Calibrating Radio Shack SWR Meter
Discussion in 'Technical Chat' started by plurpimpin, Sep 4, 2011.
  1. Sep 4, 2011 at 12:50 PM
    plurpimpin
    plurpimpin [OP] Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    I just finished installing my CB and I'm trying to tune the antenna. I have the radio shack SWR meter but I can't seem to get it to calibrate properly.
    The directions say to switch the meter to cal, key the radio up, and adjust the cal knob until the needle points a CAL. Even with the cal knob turned as far as it can go I can't get the needle past 3 on the SWR scale. Does this sound like I have a bad meter or am I doing something wrong?
    Below is a picture of the meter to give you an idea of what I'm talking about.
  2. Sep 4, 2011 at 2:39 PM
    Deserted1
    Deserted1 Hellion
    Corey
    Murrieta
    4wd Super White
    Icons
    I had a bad antenna on my Big rig that caused that to happen also... Ended up buying 2 new antennas just to fix it. Something to think about.
  3. Sep 4, 2011 at 8:18 PM
    plurpimpin
    PDX
    If I had a bad antenna it wouldn't work at all though right? I'm picking up truckers on the interstate a few miles away and I live in the mountains. Also the weather stations come in crystal clear. The radio seems to be working fine.
  4. Sep 4, 2011 at 8:24 PM
    Deserted1
    Deserted1 Hellion
    Corey
    Murrieta
    4wd Super White
    Icons
    no not always... thats just what im saying, mine seemed to be working but I could not get it to setup right... I ended up getting 2 new antennas and bam i was able to fully calibrate it and set the swr up properly.. I was hitting about 1.5 to 1.3 on my 1 and 40... with ch19 being my target... Worked flawlessly.. Try someone elses antenna and see if the problem persists...
  5. Sep 5, 2011 at 7:41 AM
    plurpimpin
    PDX
    I think I'm going to try exchanging the SWR meter for a new one first to rule out the meter being bad since I bought it 3 days ago.
  6. Sep 5, 2011 at 4:42 PM
    plurpimpin
    PDX
    Got a new meter today and it cals up perfect. Looks like I had a bad meter. Now it just needs to stop raining so I can tune my antenna.
