Trouble code P0300,P0301,P0303
Discussion in '1st Gen. Tacomas (1995-2004)' started by Antv00, Oct 17, 2023.
  1. Oct 17, 2023 at 8:21 PM
    Antv00
    Antv00 [OP] New Member
    tony
    2002 Toyota Tacoma Prerunner 2.7L
    Hello everybody , I have a 2002 Toyota Tacoma 2.7L ,mileage 274,000 miles and I've had a few trouble codes pop up recently P0300,P0301,and P0303.
    random misfire ,misfire in cylinder 1 and 3
    I can't pin point where the issue is coming from, I have a list of thing I've done and replaced,
    -new oem Denso ignition coils
    -ngk spark plugs
    -cleaned throttle body and new throttle body pos sensor
    -new injectors because old ones were cracked and leaking fuel
    -new maf sensor
    -I've inspected all of my rubber hose and I don't see any that are rotted or cracked
    -I've also change my fuel filter and my fuel pump due to previous issues regarding that
    Engine idles rough as well as some shaking and I believe somewhat loss of power, when accelerating I don't really notice shaking from engine.
    was wondering is anyone else has experienced this issue ,is so could you please help me out and leave a response of what it could be, thank you.
  2. Oct 17, 2023 at 10:07 PM
    woad4
    woad4 Well-Known Member
    2003 Tacoma Xtra Cab
    3rzfe
    chrslefty and Antv00[OP] like this.
  3. Oct 17, 2023 at 10:28 PM
    Glamisman
    Glamisman Well-Known Member
    Excellent diagnostic link… I did not know that at high engine speed that individual cylinder misfire count is disabled.
  4. Oct 17, 2023 at 10:39 PM
    Antv00
    tony
    thank you for the documents I will definitely use this as well as look into using a smoke machine to see if there is a vacuum leak as well instead of just eyeballing it ,once i do i will come back with results. thank you
    Steves104x4 likes this.
  5. Oct 18, 2023 at 7:04 AM
    woad4
    3rzfe
    you can also spray a little starter fluid around the bay and listen for idle increases. Did this problem start randomly? Or after replacing injectors etc?
    unrelated, what were your symptoms with leaking fuel injectors? Hard to start after running hot?
  6. Oct 18, 2023 at 7:09 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Excellent Q^^^
  7. Apr 23, 2025 at 7:00 PM
    kingbelga
    kingbelga New Member
    i think it may be the EGR valve.
    I have the same problem. it only happens when i start the vehicle in the morning. i can sometimes evade the codes and such by throttling up a bit till it idles normal. then it runs good all day.
    i have done all you said as well yet it still happens.
    what did you end up doing?
