Trouble code P0420
Discussion in '1st Gen. Tacomas (1995-2004)' started by el contrador, Oct 25, 2010.
  1. Aug 26, 2020 at 7:35 PM
    TacoMac156
    TacoMac156 Member
    2002 IMPULSE red tacoma 3.4 4x4 5spd
    Bilstein 5100 Deck plate mod URD short shift Magna flow cat back exhaust
    Just wanted to throw this in there, check your spark plugs! I had gotten the code a while back after replacing my o2 sensors not so long before that. The tips on my plug were all worn away leading to an in-efficient burn of fuel! This was what was giving me constant p0420 codes. Changed the plugs and the CEL actually cleared itself after a day of driving without me having to wipe it with the scanguage. Good luck!
  2. Aug 26, 2020 at 7:40 PM
    Glamisman
    Glamisman Well-Known Member
    there is a sticky on this... the OP did a fantastic explanation on the causes.
  3. Aug 26, 2020 at 9:07 PM
    1997tacomav6
    Denver
    At 630,000 miles I’ve had this code 3 times,
    It’s always been the 02 sensor.
    Cat is still running with no issues,
    Stay with the DESNO OEM part.
    You can buy them DENSO.com to make sure your not getting a fake one at a bargain price
    ShiftyShank and Black DOG Lila like this.
  4. Oct 17, 2024 at 12:56 PM
    dudester77
    dudester77 Member
    Warren
    2003 extra cab 4wd 5 speed
    Got the 420 code... checked after reading some ideas here and sure enough, exhaust leak...right after the second cat...where it joins the pipe. (I had gotten a new muffler 5 months earlier)
    2003 2.7 litre, 131k, downstream O2 sensor replaced at 80k
