Trouble disengaging 4 low
Discussion in '2nd Gen. Tacomas (2005-2015)' started by King72, Feb 18, 2016.
  1. Feb 18, 2016 at 11:49 AM
    King72
    King72 [OP] Active Member
    Paul
    Ontario
    2014 Tacoma
    Good day. My '14 4cyl manual..... I often have trouble disengaging the 4 low system.
    Is there something I am missing? Some sort of trick?
    Sometimes it takes 30 or more tries of getting it out of "low" (occasionally a bit of trouble getting it into low.) I've tried everything--- move selector to 4H when in neutral, moving a little forward, backward, shutting engine off, etc. clutch in, out; it gets downright embarrassing (so I experiment now where nobody sees !!).....
    I still have full warranty etc for another year, but I'm not ready to go crying to dealer if it's something I can remedy myself.
  2. Feb 18, 2016 at 5:40 PM
    tacoparadise
    tacoparadise Well-Known Member
    2012 tacoma 4x4
    You should have it checked under warranty.
    Obviously something is not syncing up.
  3. Feb 18, 2016 at 5:45 PM
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    I own a v6 4wd with the 6 speed and it took me forever to figure out the trick to get it in and out of 4lo. If its the same issue as me, I wasn't pressing the clutch fully to the floor for the safety switch to disengage. Give that a shot and if that doesn't work sometimes it just takes working with the 4wd for it to break in fully and shift correctly. Hope this helps. Good luck with it!
    tacoparadise likes this.
  4. Feb 18, 2016 at 6:15 PM
    tpham18nm
    tpham18nm Well-Known Member
    Same. In my 2010 4cylinder I have to push the clutch all the way to the floor. I usually shift into 4H while on the move. I think it's easier for the truck to engage 4x4. Once I approach an area where I need 4L, I stop, push the clutch all the way to the floor while the truck is still in gear, let it engage, and I drive off. To get out of 4L, I stop the truck, push the clutch all the way in, and turn the switch to 4H. Once it is in 4H I start moving again and disengage on the run. If 4L doesn't disengage, I move the truck up and repeat the cycle.
    Jerneyman[QUOTED] likes this.
  5. Feb 18, 2016 at 7:15 PM
    King72
    Paul
    Ontario
    2014 Tacoma
    Yo thanks fellas. Will give it all a try. Fortunately, if need be, there's the warranty I can fall back on.
