trouble finding 2012 wiring for trailer
Discussion in 'Towing' started by Koko, Jan 25, 2012.
  1. Jan 25, 2012 at 8:25 AM
    Koko
    Koko [OP] New Member
    I’m a new Tacoma owner—and new to this forum. I’ve got a base model 2012 access cab without the tow package. I’d like to add 4-flat wiring for a small utility trailer, which I did on my old ’96 Ranger for about $40. My Toyota dealer, though, is asking $170 parts + $90-140 labor, which seems like WAY too much unless I’m missing something.
    I read chapter 9 in the “bible” here but the links to the instructions are outdated and the wiring parts suggested won’t fit the 2012. I can’t seem to find aftermarket wiring anywhere. Any suggestions?
    And one other question: What do you do with the trailer end of the wire when it’s not being used? I used to just wrap it around the hitch on my old beat up truck but am looking for something neater on the shiny new Taco. :)
    Thanks in advance.
  2. Jan 25, 2012 at 8:34 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I believe the 2012 tail lights are the same as the 2011 so I can't see why one of those T-in wire connectors wouldn't work for your Tacoma (I'd call your dealership to confirm they are the same). In which case, it's a simple plug and play to get a flat 4 connector. As far as the plug, I zip tied mine to the hitch frame. It does hang about even with the receiver and you can see it from behind the truck, but I don't think it's unsightly at all.
    Says it will fit a 2012:
    http://www.autoanything.com/towing/75A3875A0A0.aspx
  3. Jan 25, 2012 at 1:43 PM
    Koko
    Ah, thanks Pugga.
    I dropped by the dealer in person to talk with one of the parts guys and figured out that they were quoting me a price for the wiring for a new hitch, not just bumper towing. The guy claimed Toyota doesn't have a simple T-connector wire for 4-flat --which surprises me--and encouraged me to find an aftermarket option.
  4. Jan 25, 2012 at 1:46 PM
    Pugga
    Massachusetts
    Mine also did not have the tow package so I went all aftermarket. Class 3 hidden hitch and a wire tap system like the link above for a flat 4 connection. The wiring harness just plugs into the tail lights, couldn't be any simplier!
  5. Jan 25, 2012 at 1:48 PM
    kev2lz
    kev2lz Well-Known Member
    Don't call me Bubba!
    Wylie, TX
    2012 PreRunner SR5 TX Edition
    Tailgate hoseclamps :P
    You might give UHaul a try as well. I think their wiring kits are pretty reasonable.
  6. Jan 29, 2012 at 2:20 PM
    Phillywill
    Phillywill Member
    Will
    Philadelphia, PA
    11 PreRunner 4X2 V6
    TRD Off-Road Extra Value Package
    I used after market wiring harness on my 2011 and it was really simple to do. It took me about an hour.
    Question: It looks like the bumper is an extension of the frame on my Taco. Shoudn't this be as strong as a frame hitch?
  7. Feb 14, 2012 at 8:25 AM
    TurnTheLead
    TurnTheLead Active Member
    Mississippi
    2012 PreRunner SR5 4x2 2.7
    Rubber bed mat, Tuff Tonno cover.
    I installed a curt wiring harness on my 2012 from streetsideauto.com . It was a 2011 tacoma harness and installed just fine. I have little mechanical experience and was able to install it myself, pretty easily, in about half an hour.
  8. Feb 14, 2012 at 8:31 AM
    redz80
    redz80 Well-Known Member
    Brampton, ON
    Tacoma SR5 TRD 4x4 SWB
    Theirs your first misstake!
