Trouble finding correct u-joint
Discussion in '1st Gen. Tacomas (1995-2004)' started by chato, Oct 16, 2013.
  1. Oct 16, 2013 at 4:42 PM
    chato
    chato [OP] Member
    Santa Fe, NM
    97 2.7 DLX
    Hey folks, long time reader, first time caller.
    The Taco is my girlfriends (I'm a first gen 4runner kind of guy, don't hold it against me).
    The truck is a 1997 regular cab, 2.7 4wd.
    So I pulled the driveshaft to have the u-joints replaced at the local napa.
    They pulled everything apart and now they can't get the new front u-joints to fit, they say they are 2/1000's of an inch off. Of course the old ones fell apart on disassembly so they are effed.
    Napa contacted the dealer, gave them the vin, and apparently the dealer part doesn't fit either.
    I have to get this thing back on the road by Friday to head out on an elk hunt, and I am starting to get a bit worried.
    Anybody know anything about a different size u-joint for these trucks?
  2. Oct 16, 2013 at 5:07 PM
    chato
    chato [OP] Member
    Santa Fe, NM
    97 2.7 DLX
    fyi despite being a regular cab, it has the double cardon in front. which on further reading, is non-serviceable?
  3. Oct 16, 2013 at 6:02 PM
    Inverno4
    Inverno4 Well-Known Member
    Baltimore, MD
    04 SR5 4x4 TRD Xtra Cab
    If the double cardan is inside snap rings, there should be a few that fit it. They are:
    Neapco-#1-5800
    Precision-#513
    Spicer-#5-2532x
    Rockford-#407-10
    All of those are 1.125 cap diameter which about two hundredths smaller than the recommended replacement I believe.
    If it's outside snap rings like my '04, the Rockford #2540 fit (just changed mine). It's a 1.0625 cap and 3.19 width end to end.
    Find out the cap diameter and width you need, to know if these fit.
  4. Oct 17, 2013 at 7:41 AM
    chato
    chato [OP] Member
    Santa Fe, NM
    97 2.7 DLX
    Thanks, that is super helpful.
  5. Oct 17, 2013 at 3:48 PM
    chato
    chato [OP] Member
    Santa Fe, NM
    97 2.7 DLX
    precision 513 did the trick.
    again, thanks for the help.
  6. Oct 17, 2013 at 3:50 PM
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    glad to hear you got er back on the road
  7. Oct 17, 2013 at 3:53 PM
    Dirty Pool
    Dirty Pool SEND ME TO THE 'LECTRIC CHAIR
    59.4 Miles, 56.67*NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, Both 31" MTZ's and 33" Toyo's, 01 Center console, Map lights, Disraeli gears
  8. Oct 17, 2013 at 4:37 PM
    Inverno4
    Baltimore, MD
    Dirty Pool taught me almost everything I know!
    Good to hear it's running again.
  9. Oct 17, 2013 at 4:54 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    Aw shucks, you are the one that had the guts to take on the job. The good sense to ask the right questions and a stick to it attitude to get er done.
    Not to mention "discovering" the outside clip joint that "no one makes".
  10. Oct 18, 2013 at 7:08 AM
    chato
    chato [OP] Member
    Santa Fe, NM
    97 2.7 DLX
    it is indeed. had to learn the hard way.
    Got the DS back last night, looks pretty good, if a maybe a little manhandled.
    will reinstall today, then headed up to the mountains for an elk hunt this afternoon. I guess thats a good way to test the repair.
    Thanks again for all the help fellas.
  11. Oct 18, 2013 at 7:44 AM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    FWIW - my 2003 Doublecab came up as a Precision #513 too, problem was, it actually took a Precision #387.
