Trouble getting out of 4WD
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DwightKSchrute, Jan 15, 2019.
  1. Jan 15, 2019 at 6:07 PM
    DwightKSchrute
    DwightKSchrute [OP] Well-Known Member
    2017 Magnetic Gray Tacoma TRD Off Road 4x4
    Hey TW, I've noticed that my 2017 TRD OR dbl cab does not immediately switch from 4wd to 2wd...I drove the other day in snow using my 4H setting and when I parked at work, I switched it back to 2WD. The 4WD indicator on the dash just blinked and I never hear a switch in the glove box area like I normally do. I tried putting in in drive only to hear a "thump" as I pulled forward. This disengaged the 4wd. Any takers? I heard its not preferrable to use the 4wd on flat ground...is that really what is causing this? I should also note, that I've had problems with my tires in the past and this issue last winter. I took it to toyota and they put four TRD sport tires on and the problem went away. They gave me four new tires and said the problem was solved, but it happened again this winter.
  2. Jan 15, 2019 at 6:10 PM
    CZ-Jack
    CZ-Jack Well-Known Member
    2019 DCSB OR Cement
    Engage and disengage while moving, not at a standstill.
    Jaque8, kgilly, TacoCon and 5 others like this.
  3. Jan 15, 2019 at 6:14 PM
    Shellshock
    Iowa
    Shift to and from 4 high while moving. Shift to and from 4 lo stopped in neutral after engaging 4 high.
  4. Jan 15, 2019 at 6:16 PM
    DwightKSchrute
    Thanks!
  5. Jan 15, 2019 at 6:18 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    As they said, 4wd really prefers to be engaged and disengaged while moving. I just lift my foot off the gas then turn the knob, and it’ll switch damn near instantly, sometimes with a clunk. That’s nothing to worry about.
  6. Jan 15, 2019 at 6:20 PM
    DwightKSchrute
    Thanks a lot. I lived in north florida before and never drove in the snow...Omaha is putting my truck to work!
  7. Jan 15, 2019 at 6:25 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    You can use 4wd on flat ground. Its dry pavement where you gotta turn sharply you want to avoid in 4wd.
  8. Jan 15, 2019 at 7:06 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Bears, beets, battlestar galactica!
  9. Jan 15, 2019 at 9:27 PM
    hrivera007
    hrivera007 Well-Known Member
    2017 Off Road Auto
    Identity theft is a crime, millions of families suffer each year
  10. Jan 15, 2019 at 9:28 PM
    verynearlypure
    verynearlypure Clean & Decent
    Ernest
    The Buckeye State
    2015 BRM DCSB TRD OR
    Ray 10’s & Basic Bastard Goodies
    Michael!
    Sub_Par and hrivera007 like this.
  11. Jan 16, 2019 at 6:42 AM
    DwightKSchrute
    Okay, tested it out this morning.. Driving to work like normal, no speeds in excess of 40 mph. Flipped the dial to 4wd and it feels like it may have engaged, but the light for the 4wd is just blinking. The truck also feels like its kind of hard to control. If I had to maneuver, it would be delayed. Flipped the dial back to 2wd and its still blinking, it still feels like its in 4wd and I can't get it to stop blinking or return to 2wd.
  12. Jan 16, 2019 at 7:04 AM
    nmum
    nmum Well-Known Member
    Didn't post yesterday because didn't think it was applicable and I haven't really had a chance to try out the 4WD in a Tacoma yet.
    But in my previous truck it sometimes took a while to switch between 4WD and 2WD too. I think the two tips or tricks were either to shift it into reverse and then go back into drive. And the other was to give a quick press of the gas, kind of like a blip of the gas pedal.
    Can't remember the reasoning behind it. It might've been something about it not switching while the system was under load or something.
    The 4WD system might be different then with the Tacoma but doesn't hurt to give it a try.
  13. Jan 16, 2019 at 7:39 AM
    DwightKSchrute
    Not sure that's a normal function of a tacoma with 17k miles on it though, right?
  14. Jan 16, 2019 at 7:50 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Were you driving in a straight line? Did you lift your foot off the gas pedal for a moment as you tried to engage/disengage it?
  15. Jan 16, 2019 at 7:54 AM
    DwightKSchrute
  16. Jan 16, 2019 at 7:54 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Not necessarily a requirement but I find that it engages/disengages a whole lot easier that way.
  17. Jan 16, 2019 at 7:59 AM
    DwightKSchrute
    During my 15 minute commute to work, it did not disengage and throughout the entire drive the 4wd light was blinking.
  18. Jan 16, 2019 at 8:02 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah that seems odd. And you're just trying to go from 2hi to 4hi, or visa versa? Nothing to do with 4lo at the moment?
  19. Jan 16, 2019 at 8:11 AM
    adamant365
    adamant365 Well-Known Member
    Adam
    Kentucky
    '09 SR5, DCSB, 4x4
    This part has me curious. So when you parked at work, were you on snow the whole time? Or if you were on dry pavement were you going straight or nearly straight the whole time you were parking? I don't know your parking situation, but I would expect several 90 degree turns into a lot/parking space, etc. If any of those turns are on dry pavement, it's not exactly great for the t-case.
    Joe23 likes this.
  20. Jan 16, 2019 at 8:12 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    for me i find it easier to make sure im coasting in straight line. I shift to neutral (even though you dont have to) and getting in and out of 4hi is quick and painless, the only time i hear a clunk is usually when my wheels are slightly turned.
    TRDPro916 likes this.
